Road noise ?
Old Jan 1, 2025 | 02:30 PM
ROUTE 66's Avatar
ROUTE 66
Default Road noise ?
Car is a 2007 C6 Z06 65,000 miles
I have started hearing a whine / rumbling roaring noise. Seems to be coming from the rear of car. I think it is Too loud to be a tire.
Are the hubs difficult to replace?
I think it might be a Right rear hub.
Thanks E
Old Jan 2, 2025 | 09:57 AM
PCMusicGuy's Avatar
PCMusicGuy
The hubs are a common failure point. I'd jack up the rear and check the tire for obvious play. If you have the tools and access, they aren't the worse thing to replace, but it ain't for the faint of heart.
Old Jan 2, 2025 | 11:56 AM
ROUTE 66's Avatar
ROUTE 66
Thank you.
Are there any special tools required. any thing made just for removing the hub?
Old Jan 2, 2025 | 01:16 PM
torquetube's Avatar
torquetube
Originally Posted by ROUTE 66
Thank you.
I don't know if you'd consider these special tools, but you will need a big socket for the axle nut, a way to separate a ball joint (depending on how stuck yours is, anything from a dead-blow hammer to a proper ball joint tool), and a Torx T55 socket for the three bolts that attach the hub to the upright. Torque spec is 96 lb-ft.
Old Jan 3, 2025 | 11:10 AM
ROUTE 66's Avatar
ROUTE 66
Default Thank You.
Thank You. Your input will be most helpful This is what I needed to make the job more enjoyable.
To Road noise ?
