P0171 and P0174 codes
Old Jan 4, 2025 | 09:31 AM
herca's Avatar
herca
Default P0171 and P0174 codes
Hi folks,
About 3 weeks ago my check engine lit up randomly. I thought it's the usual fuel system small leakage code so I didn't hurry to read the ECU, until it went away on the next 2-3 trips. Then it came back this week and I read it out immediately. I got P0171 and P0174 codes. The car was acting as always, no dropping of rpm or bad idle, nothing. I deleted it and it hasn't came back yet.
What do you think might be the cause?
The car is tuned with catless lt headers and factory oiled K&N air filter (I put it in ~3000kms ago).
Old Jan 4, 2025 | 11:23 AM
C6VetteLover's Avatar
C6VetteLover
You have a vacuum leak affecting both banks. Check the air intake tube at the throttle body. Or the MAF is misreporting.
Old Jan 4, 2025 | 12:38 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If both bank fuel trims are elevated and if running at 3000 RPM decreases them you have a vacuum leak...if fuel trims are near 0 at idle but increase under load you have either a fuel delivery or MAF issue...this has nothing to do with your EVAP system (small leakage)
Old Jan 13, 2025 | 12:26 AM
herca's Avatar
herca
I know, I only said that because that's the reason I didn't pull the codes, because I thought the CEL is for the EVAP system.
Thank you for your help guys, I will check them.
Old Jan 15, 2025 | 08:12 AM
Spaceme1117's Avatar
Spaceme1117
Also, check your intake manifold bolts and re-torque.
To P0171 and P0174 codes
