Drivetrain slack?
Old Jan 21, 2025 | 04:09 PM
Corvettechris86's Avatar
Corvettechris86
Default Drivetrain slack?
Is it normal lets say when using the paddles in an A6 transmission cruising around 2000 rpms to feel like the drivetrain has slack when getting on or off the throttle even lightly? The torque tube was apart less than 10k miles ago and the guibos replaced even though they were still good. Is this normal with an automatic? It’s almost like “on/off” slack and seems more noticeable at slow speeds in “lower rpms” while using paddles. Don’t notice anything in drive not using the paddles… Thanks
Old Jan 21, 2025 | 07:15 PM
ClothSeats's Avatar
ClothSeats
Was the slack apparent before the guibos were replaced?
Old Jan 21, 2025 | 08:28 PM
davidfarmer's Avatar
davidfarmer
that's general how cars with torque converters work.
Old Jan 21, 2025 | 10:11 PM
Corvettechris86
Honestly I never noticed it until using the paddles passing through a 15 mph speed limit area in 2nd gear. As long as it’s normal with the torque converter, I had no idea…Just wanted to make sure, don’t want to rebuild the driveshaft again in the garage. I used febi bilstein guibos which held up good in my C5 so doubt they deteriorated over 10k miles plus being an A6 with torque management. Thanks for confirming
Old Jan 22, 2025 | 05:16 PM
davidfarmer
honestly I haven't drive a paddle C6 in a long time but it's still a traditional automatic. I assume the torque converter would not be locked at low speed/2nd gear as you describe but I could be wrong
Old Jan 22, 2025 | 07:20 PM
DSOMC6's Avatar
DSOMC6
Oem tq converter locks at 1800rpm iirc.
Old Jan 23, 2025 | 12:10 PM
Corvettechris86
Is there anything else that would cause “slack” other than bad couplers? I’ll have to try cruising at say 3000 rpm’s and see if it still does it… hoping it’s just normal with the torque converter.
Old Jan 23, 2025 | 02:22 PM
ClothSeats's Avatar
ClothSeats
There could be excessive play in the transmission or differential. To a lesser degree, I suppose there could be play in the splines as well.
To Drivetrain slack?
