Sequential Taillights Stock C6??!!
Old Jan 28, 2025 | 06:36 PM
06BlackCherry's Avatar
06BlackCherry
Default Sequential Taillights Stock C6??!!
My wife pointed out to me the other day that the passenger side taillights were blinking sequentially when I used the turn signal, but the driver's side lights were blinking simultaneously. I checked the bulbs on the passenger side and found the inboard bulb looked like it had a burned filament, but the outboard light looked fine. So I replaced the inboard bulb but the passenger side taillights are still blinking sequentially. Is there something else going on here?
Old Jan 28, 2025 | 06:48 PM
BADBIRDCAGE's Avatar
BADBIRDCAGE
There’s a plug in sequential device available should you desire it. It was on my 2006 and I removed it quickly after purchase. It’s not all that impressive with two lights.
Old Jan 28, 2025 | 07:00 PM
sjw91's Avatar
sjw91
I have no personal experience with them, but just did a quick search. Apparently the harness with the delay installs on the outboard taillights to make them look sequential. You wouldn't have seen it when replacing the inboard bulb.
https://www.vette-lights.com/product...xoCbEgQAvD_BwE
06BlackCherry
What does it look like?
Old Jan 28, 2025 | 07:09 PM
06BlackCherry
This red cap is the only thing that looks different. I don't see anything else that looks like it's plugged into the wiring harness anywhere else.
Old Jan 28, 2025 | 07:15 PM
sjw91's Avatar
sjw91
Yeah, remove that. The harness should look the same on both lights.
Old Jan 28, 2025 | 08:04 PM
BADBIRDCAGE
Inner light flash 1/4 second before outer light. Then both stay on on brake, turn signal repeats.
Old Jan 28, 2025 | 08:15 PM
06BlackCherry
I removed that intermediate module with the red cap. There's a small circuit board underneath the red cap, but no switches or anything. I have no idea if it was meant to control all 4 lights or if the previous owner had no idea they needed two. In any event, they're all operating normally now.
Old Jan 28, 2025 | 08:28 PM
sjw91's Avatar
sjw91
No, it wouldn't have controlled both sides. When signaling, it just ads a delay on that bulb to make it look like they're sequential. Did you check the driver's side outboard light?
Old Jan 28, 2025 | 08:35 PM
Moved over C6 Tech since this is a C6 issue.
To Sequential Taillights Stock C6??!!
