Heater hose “t” cracking
Old Jan 30, 2025 | 10:19 PM
Corvettechris86's Avatar
Corvettechris86
Default Heater hose “t” cracking
Noticed tonight the “T fitting where the hoses branch off to the heater core has a crack starting. For now I put a hose clamp around it to prevent it from cracking more before the proper fix. Do they make a replacement T fitting or do you have to replace the whole fitting with hoses? From what little info I found I read it’s not serviceable. Thanks
Old Jan 31, 2025 | 05:43 AM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
throw a brass T in it and you'll never have to worry about it again. I did it shortly after buying mine. (I think its 3/8ths off the top of my head but double check me on that)
Amazon.com: Dorman 55108 3/8 In. Brass Tee Connector Universal Fit : Automotive Amazon.com: Dorman 55108 3/8 In. Brass Tee Connector Universal Fit : Automotive
Old Jan 31, 2025 | 07:16 AM
Corvettechris86
I seen those but thats the smaller one closer to the throttle body right? This is the larger one on the passenger side near the water pump where it branches off to the heater.
Old Jan 31, 2025 | 07:19 AM
StayinStock
Nope 3/8ths would be the bigger one that comes off of the coolant reservoir right in front of the radiator.
Old Jan 31, 2025 | 08:14 AM
tektrans's Avatar
tektrans
I replaced mine w brass about a year ago after reading a similar thread.
Old Jan 31, 2025 | 08:51 AM
blownbayou's Avatar
blownbayou
Same here
To Heater hose “t” cracking
