Rear diff axle cv boot...fluid leak...
Old Feb 2, 2025 | 11:56 AM
C6ZO6V3's Avatar
C6ZO6V3
Default Rear diff axle cv boot...fluid leak...
Anyone replace just rear diff axle CV boot successfully? Meaning, was a torn boot the likely problem and not seals in the diff itself...
Old Feb 2, 2025 | 08:15 PM
C6VetteLover's Avatar
C6VetteLover
To do it right replace the axle. You can find quick boots at auto parts stores but they are messy. One a boot starts to leak grease, water and dirt can enter and destroy the joint.
Old Feb 2, 2025 | 10:21 PM
C6ZO6V3's Avatar
C6ZO6V3
wpuld be best...I'll check fluid level...gong to change trans and diff fluid anyways....always something...
Old Feb 4, 2025 | 12:25 AM
Dano523's Avatar
Dano523
That is diff fluid, not joint grease, so need to go down the rabbit hole of if the diff seal lips just wore out on its own, or if the diff output shaft bearing went bad/has too much slop in it that caused the seal to fail, and diff needs to be pulled apart to replace the output shaft bearing as well.
Old Feb 4, 2025 | 12:37 AM
C6ZO6V3's Avatar
C6ZO6V3
thanks for the diagram! I figured it was fluid not just grease...I'll be toppings off the fluid hopefully this week and not how much it took. Nothing funny noises and feels fine. Diff has been built before (at least hardened output shafts and sone other things i believe). I'll be heading to ROM Transmission for them to inspect.
Old Feb 4, 2025 | 05:01 PM
davidfarmer's Avatar
davidfarmer
those outer seals can leak if they are slightly overfilled also, lots of us have put in a little extra fluid thinking we were helping the car only to find out later we were creating leaks.
Old Feb 4, 2025 | 07:39 PM
C6ZO6V3's Avatar
C6ZO6V3
that is good to know. I have not changed diff fluid in a C6...I assumed you just filled up to where it would drip out of fill hole? How could you add "too much"...unless you slammed the cap on fast while it was trying to flow out after filling???
is there a free download service manual for C6 Z06?
To Rear diff axle cv boot...fluid leak...
