Need help with rcdlr
I hook up the tech 2 scanner to try to reprogram the new rcdlr but it says that it is unable to communicate with the ecm and it says it cant read the vin off the bcm. I have to clear the codes on the dtc for the unknown rcdlr then turn off the tech 2 and turn it back on then it says that the rcdlr is locked. The entire time I'm doing this the security light is on I've been in the car for probably 45 min with the "car trying to start" mode and the security system is still locked. I have tried it multiple times for probably a total of 3 hours, with the battery charger hooked up and not hooked up. The only way for me to get the security light to go away is to clear the codes for the unknown rcdlr but even after that nothing happens, even tried the key slot then. I've tried clearing all of the codes for the theft deterrent using the tech 2 but still no luck. I have tried everything I can think of and have spent hours and hours doing research and still at a stand still. Any help or suggestions would be greatly appreciated! I think the next steps I would try is getting a new ecm already programmed to the vin and if that doesn't work I'll probably put a Holley terminator x in it
PIC4880A: RCDLR Locks Up When Programming Or No Communication - keywords chime chirp detected DIC fob horn key lock message no program reminder RKE transmitter up - (Oct 8, 2008)
Subject: RCDLR Locks Up When Programming Or No Communication
Models: 2005-2009 Cadillac XLR
2005-2009 Chevrolet Corvette
This PI was superseded to update model years. Please discard PIC4880.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some technicians may comment that the RCDLR (Remote Control Door Lock Receiver) "Locks Up" during programming or when attempting to communicate or there is no communication with the RCDLR.
This may be the result of a time out feature within the RCDLR or when programming the RCDLR. It is possible that the necessary fuses that needed to be removed for programming were not removed.
Recommendation/Instructions:
Prior to establishing communication with the RCDLR, press the mode switch as if you were attempting to start the vehicle. This will "wake up" the RCDLR and should allow communication. If there is a delay when attempting to communicate with the RCDLR, the mode switch may need to be pressed again to "wake up" the RCDLR.
If attempting to program the RCDLR and the module "Locks Up" it can be reset by removing the RCDLR fuse (#11 in the UBEC) for at least 30 seconds or longer and then reinstalling it. Once this fuse is reinstalled in the UBEC, there will be a 2 minute window to restart the programming of the RCDLR through TIS2WEB.
Failure to restart the programming of the RCDLR through TIS2WEB within 2 minutes may cause programming to fail and this procedure will need to be repeated.
It is recommended that the Tech 2 remain connected to the vehicle and that the TIS2WEB application is open and ready to program the vehicle prior to reinstalling RCDLR fuse #11 into the UBEC. Once you are ready to program, install fuse #11 and initialize programming immediately.
Important:
Prior to programming per the information below, the Radio and HVAC Fuses MUST be removed and the ignition must be in "Key On Engine Off Mode" The radio and HVAC fuses can be located in the BCM fuse block on the passenger's side floor electrical center. One of the fuses is labeled RDO/S'BAND/VICS and the other is labeled HVAC/PWR SND.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
#PIC3225J: Set Up RCDLR After Replacement - (Apr 13, 2018) Subject: Set Up RCDLR After Replacement Chevrolet
Corvette
2005 - 2013
All
All
All
All
Supersession StatementThis PI has been superseded to update Model Years.. Please discard all copies of PIC3225H.
Condition/ConcernThere have been questions regarding the programming and/or set up when replacing the Remote Control Door Lock Receiver (RCDLR). The following steps can be used as a guide when replacing the RCDLR. As always, please refer to Service Information (SI) for the replacement instructions.
Recommendation/Instructions2004 Cadillac XLRImportant: When replacing ANY components in the RKE system, have the Parts department contact Partech to verify that the correct PN components are being ordered. Originally, the RCDLR and the transmitters were only available as a preprogrammed matched set for the 2004 Cadillac XLR. This is no longer the case. All components are currently available separately.
- Plug in the new RCDLR
- Perform module setup in the scan tool.
- Program the Theft Deterrent System learn using either the 10 or 30 minute theft relearn procedure. (eSI Document ID # 1460252). Canada and Export vehicles will not allow 30 minute autolearn procedure.
- Learn the tire pressure sensors. (eSI Document ID # 1396476)
- Verify that the Tech 2 is on version 33.004
- Perform the RKE transmitter programming procedure. If the RCDLR has been replaced, select the instructions in SI for "New RCDLR ONLY" (eSI Document ID # 2310804)
- Perform the RCDLR Setup procedure using the Tech 2.
- Perform the Theft Deterrent System learn using the 10 or 30 minute theft relearn procedure for Domestic, Canadian, or Japanese vehicles. Other Export vehicles will not allow the 30 minute autolearn procedure.
- Perform the TPM sensor learn procedure.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on
Condition/Concern:
Important:
If you buy a new DVOM get a 12 volt incandescent test light and not an LED !!...easiest way to check fuses... anyone who works on their car should have one...I use my test light more than my DVOM.
Put the battery in as well as fuse 11, and pulled the radio and HVAC fuses as per your replies instructions. Tried the new rcdlr with the new key fob programmed to it because it was still plugged in. First I hit the start button and the same thing happened in the video as expected, so I turned on my tech 2 and tried to set up the new rcdlr but before I did that I popped the #11 fuse out waited 15 seconds and put it back in to start the 2 minute timer, go to setup the new rcdlr on the tech 2 and it says "No communication with vehicle. Check diagnostic link connector. Check ingnition (On/Off) ). The next screen says "Unable to retrieve VIN from BCM." I try the same thing again and it says "Test not completed. Controller is locked." I go to theft and deterrent to read the codes and they list:
Remote control door lock receiver U1000 Class 2 Data Link
Body control module U1000 Class 2 Data Link Symptom 00
Body control module U2105 Symptom 00 Lost communication with Engine control system
Body control module B3949 Symptom 05 Right front turn signal circuit short to battery or open (its unplugged)
Body control module U2108 Symptom 00 Lost communication with ABS/TCS Control system
Body control module U2100 Symptom 00 CAN Bus communication
I go to clear the codes and I get the " No communications with vehicle. Check diagnostic link connector. Check ignition (On/Off) ) message again.
I tried some other functions with the tech 2 as you requested and I was able to do the lights for the car inside and out, horn, door switches, I tested all the gauge cluster functions and the HUD and all of those worked but whenever I would try to do anything engine or ecm related I would get the same " No communications with vehicle. Check diagnostic link connector. Check ignition (On/Off) ) message. I tried to activate the starter relay which came with that message and I tried the fuel pump relay which I know works because every time I hit the start button the fuel pump primes.
I checked the DTC for the instrument cluster while I was there and here are the codes that popped up.
Instrument panel cluster U1000 Class 2 Data Link
Instrument panel cluster U1193 Lost communications with RCDLR
Instrument panel cluster U1040 Lost communications with EBCM
Instrument panel cluster U1017 Lost communications with Engine control system
Heads up display U1040 Lost communications with EBCM
Heads up display U1017 Lost communications with Engine control system
Heads up display U1000 Class 2 Data link
I was able to clear all of these successfully. Tried to start and still no luck, the security light was still on the whole time.
________________________________________ ________________________________________ ________________________________________ ______________________________________
ORIGINAL RCDLR
Then I plugged in the original rcdlr and used the original key fob that is not programmed to the new rcdlr. I popped out the #11 fuse to reset the ecm and tried to open the door which didn't open, put the 11 fuse back in and the passive entry worked so that confirms that the 11 fuse terminal is getting power or the RCDLR wouldnt work at all. I tested both key fobs that I had in my pocket to make sure it was the old key that was working still by popping the trunk and the new key didn't because I unplugged the new RCDLR.
With the original RCDLR plugged in I was able to clear the code that I got for it previously and was able to get the security light to go away( also goes away when you pop the #11 fuse). Tried to start the car and still nothing. I checked the Instrument panel DTCs again and got
and no communication to the ECM
codes were able to be cleared.
Tried to do more functions with the ecm and still no communication to the vehicle.
Pushed start button to reset 2 minute timer and Tried to setup new RCDLR and it said "Test not completed. Controller is locked." This is the original rcdlr so how could it not read the vin from the car that its been in? I checked the codes in the theft deterrent again... ecm no communication
Body control module U1193 Symptom 00 Lost communication with RCDLR
Couldn't clear the codes due to no communication to the vehicle.
Popped fuse 11 out again and the security light went off tried to start car, no luck. The security light came back on, I waited for 15 minutes still didn't turn off.
Pin 2: fluctuated between 0.2-0.5 volts
Pin 6: 3v
Pin 14: 1.41v
Pin 16: 13.85v
I also installed a brand new ECU with the cars vin programmed to it just to see if it would work but still no communication to the Tech 2 issue.
Also tried unplugging the RCDLR like you mentioned but that did not help either.
Pin 6: 3v
Pin 14: 1.41v
Pin 16: 13.85v
What is the resistance reading with battery disconnected across 6 and 14 ??…120 or 60 ohms ??
Do you know how to read the Information Bus wiring schematic ??…sometimes it best to break the bus in half and check for continuity in either direction…X184 may be a good place to split the network in half...now on the wiring for an 06 I posted that is the non OEM wiring which does not include the connectors that may be in between each module and there is no OEM wiring for that year…I will post my 08 which does show all the connectors…best to buy a sub to Alldata DIY for a month or a year…this is too labor intensive to show you every pin out, location and connector view.
