Vette lights resistors-placement?
Feb 23, 2025 | 12:07 AM
What or where do you guys attach your Vette Light LED bulbs resistors to, for the brake lights.
Feb 24, 2025 | 06:19 PM
Can I just let the resistor just hang free in the back of the lens?
Feb 24, 2025 | 06:54 PM
I just let mine hang free, but have only had them installed a few months for what it's worth
Feb 24, 2025 | 08:36 PM
Feb 25, 2025 | 10:31 AM
Use some heavy duty double sided tape and mount it to the bumper just below the tail lights. It's easy to reach and doesn't take much time at all.
Feb 25, 2025 | 03:10 PM
Much thanks for the replies. The Vette lights are awesome. Had the lens tinted also.
Feb 27, 2025 | 12:03 PM
Double sided tape. Cleaned the area and then heated it up. These things aren't going anywhere.
Feb 27, 2025 | 04:19 PM
Only thing is you have 4 resistors to place
Feb 27, 2025 | 08:55 PM
Quote:
Originally Posted by
laserred
Yeah right behind the tail lights. They need some force to come off.
Feb 28, 2025 | 12:45 PM
Have you checked them after some use? The resistors get really really hot. I just wonder if it melts the glue. I used metal wire tie onto the existing wires and a heat shield between for now with a plan to improve it later.
Feb 28, 2025 | 03:27 PM
Aardwolf
I have not but had a similar set up on my c5 and no issues. I'll check them in a week to make sure. Thanks for the heads up
