DeWitts fitment question for C6 Z06
Old Feb 24, 2025 | 02:15 PM
Gearbhall's Avatar
Gearbhall
Default DeWitts fitment question for C6 Z06
I have a 2007 Z06 with the stock radiator and fans, NA build making 621whp. Under extended periods of spirited driving or in 90*F+ heat in stop and go traffic it gets really hot. I know there is a difference if the AC is running or not. That being said to get the temps down and just generally have more cooling capacity I am wanting to get the DeWitts radiator with the internal cooler. I've seen comments about people maybe needing oil lines for that cooler but not sure if that applies to my Z06 or not.
32-1139105A is the part number I am looking at, and I called DeWitts but want to make 100% sure I don't need anything but the radiator.
I am planning on getting prospeed fans later/next year. Only doing one thing for now due to budget constraints.
Old Feb 24, 2025 | 04:51 PM
Gearbhall's Avatar
Gearbhall
nvm I called DeWitts again and confirmed I do need the oil line kit. I can't find a way to delete my post though.
Old Feb 25, 2025 | 06:24 AM
Spaceme1117's Avatar
Spaceme1117
Yes, you will need the oil lines. They connect the radiatior oil cooler to the oil ports near the oil filter. Will significantly help with the heat.
To DeWitts fitment question for C6 Z06
