Strange Transmission Noise
Old Mar 6, 2025 | 04:37 PM
LouMcDo91's Avatar
LouMcDo91
Default Strange Transmission Noise
I recently have started noticing something odd about my car. If I hit the brakes really hard, I hear this strange metallic spinning sound. I can definitely confirm that it is either the transmission or the bar that connects it to the engine. Sometimes the sound will continue for a little while after I smash the brakes, sometimes it seems to go away within a few seconds. But it most definitely isn't coming from the engine. Any ideas what this may be?
Old Mar 6, 2025 | 08:10 PM
gsflyer2011's Avatar
gsflyer2011
Your pads are so worn that backing plates hitting rotor?
Old Mar 6, 2025 | 08:33 PM
LouMcDo91's Avatar
LouMcDo91
could that be it? I know a decent bit about vehicles but when it comes to Transmissions I am woefully ignorant.
Old Mar 7, 2025 | 08:10 PM
gsflyer2011
I was talking about your brakes, transmissions usually do not make that kind of noise while braking hard.
Old Mar 7, 2025 | 08:28 PM
LouMcDo91's Avatar
LouMcDo91
breaking hard isn't the only time it makes the sound, that's just what triggers it. After I break really hard, the transmission will make a whining sound for a little while. Sometimes it's only for a few seconds and sometimes it lasts for a few minutes.
Old Mar 8, 2025 | 12:54 AM
Téva's Avatar
Téva
6th Gear
Is it the sound you can hear at 2mn in this vidéo?
Old Mar 8, 2025 | 01:51 AM
Swoope's Avatar
Swoope
Sounds like a throw out bearing failing. And the adjustment is off which is causing you not to be able to get into reverse. Air in the system?
Good luck.
Beers
Old Mar 10, 2025 | 10:50 AM
LouMcDo91's Avatar
LouMcDo91
https://youtu.be/sF6EASlc_IU?si=Xr3SRh2AkW5bPxat
Sadly, no. This is the sound its making:
And I know it sounds like a belt, but I can 100% confirm it isn't.
Old Mar 11, 2025 | 02:27 PM
VettingProcess's Avatar
VettingProcess
throwout bearing or torque tube bearing/s possibly?
To Strange Transmission Noise
