Tr6060 fluid type
Old Mar 13, 2025 | 12:32 PM
Mccarthy12589's Avatar
Mccarthy12589
Default Tr6060 fluid type
I know this has been discussed many times. I’m getting conflicting answers. I’m changing the fluid in my 2011 grandsport with the manual. The person I bought the car off of supplied me with 8 qts of Mobil 1 full synthetic ATF. From what I read I should be putting non synthetic ATF in there. Can anyone concur? Am I OK using this fluid? People have told me the full synthetic eats away at the carbon on the synchronizers
Old Mar 13, 2025 | 05:12 PM
Dzv69's Avatar
Dzv69
I had my TR6060 R&Rd by a Tremec specialist/distributor a few years ago, he told me to use Havoline or Castrol MERCON V trans fluid for the refill when i got it back from him. That's exactly what i filled it with, zero issues since.
Old Mar 13, 2025 | 08:24 PM
Mccarthy12589
Yea I called a place in Texas ad that’s who gave me the info about not using the synthetic. I just think it’s strange that ya can’t really find a concrete answer anywhere. Usually the web has some pretty solid info. Thanks
Old Mar 13, 2025 | 09:53 PM
JetstreamGS's Avatar
JetstreamGS
Factory fill is Dexron III ATF. Not sure if that is still produced or not. RPM transmission recommends Royal Purple Synchromesh. I put that in and no issues. Stock trans was grinding second gear at 6k miles.
Old Mar 14, 2025 | 06:31 AM
Spaceme1117's Avatar
Spaceme1117
I would just use the stock GM fluid. That has worked best for me.
Old Mar 14, 2025 | 11:10 PM
08z51m6Ls3's Avatar
08z51m6Ls3
Just use the ac delco factory fluid. I replaced mine recently with just 15K miles on the car.
made a BIG difference in how smooth the transmission is while rowing the gears.
Old Mar 17, 2025 | 02:12 PM
Dzv69's Avatar
Dzv69
Anyone have the ACDelco part number for the Dexron III ATF, I’m seeing Dexron VI in my search results - or any other brand/mfg with Dexron-III on the label is compatible with the TR6060 transmission ?
Old Mar 17, 2025 | 04:17 PM
DarkC-6's Avatar
DarkC-6
Originally Posted by dzv69
anyone have the acdelco part number for the dexron iii atf, i’m seeing dexron vi in my search results - or any other brand/mfg with dexron-iii on the label is compatible with the tr6060 transmission ?
88861800
Old Mar 18, 2025 | 01:37 PM
Dzv69's Avatar
Dzv69
Originally Posted by DarkC-6
88861800
Old Mar 22, 2025 | 09:51 PM
Epitome's Avatar
Epitome
I have a 2010 GS manual coupe. I’m in the middle of doing a bunch of maintenance. I’ve read as much as I could about which ATF fluid to use in the 6060 manual transmission and the clear winner was Redline D4 ATF, which is synthetic. I saw nothing that warned against synthetic use. Here is a pic from a Camaro thread where he emailed Redline tech about D4 ATF for the T6060:
Here is another informative answer from Redline:
Old Mar 23, 2025 | 10:37 AM
JetstreamGS
I tried the D4 in my stock box in an attempt to remedy a grinding second gear synchronizer. Didn’t help. Ordered a RPM Level 7 and put in the Royal Purple Synchromesh they recommended. Shifts like butter.
To Tr6060 fluid type
