Clunk Clunk Clunk
Old Apr 29, 2025 | 09:22 PM
LouWinget's Avatar
LouWinget
Default Clunk Clunk Clunk
2009 base coupe A6
I just wrapped up changing the passenger side rear wheel bearing hub Drove it out of the garage and just far enough down the street to achieve about 15 mph which, by that point, was accompanied by a loud "clunk, clunk, clunk! Put it back in the garage What now? Opinions and advice requested and welcomed, please.
Old Apr 30, 2025 | 12:04 AM
torquetube's Avatar
torquetube
Originally Posted by LouWinget
2009 base coupe A6
Assuming everything got put back and torqued:
There are three T55-head screws that attach the hub to the upright. The bottom screw may be hitting the backs of the wheel studs. If so, you can clearance the end of the screw with a grinder, or purchase the shorter screw GM makes for this application on the ZR1.
