Rough running issues
Old Apr 30, 2025 | 02:54 PM
bruins4ever's Avatar
bruins4ever
Default Rough running issues
I've got a 2006 ZO6 with H/C upgrade from RPM Motorsports, and this was done years ago. 39k miles on the clock. Here is the issue
Runs really rough, but idol's between 850-900.
fuel pressure at 62psi at the rail..cold engine
Ran a scan and test on the injectors, no issue
replaced both spark plugs and coils
dumped 8 gallons of fuel from the tank, just filled up a few days before. Put seafome and a bottle of lucas in it and filled it back up with 93.
Still not sure why it would run rough...any ideas??
Old Apr 30, 2025 | 03:12 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If you tested the injectors and I’m assuming you did an injector balance test warm up the engine and post some data PIDS from your scan tool…MAF in grams per second (no loads) and fuel trims…coil packs are pretty much bulletproof and rarely go bad…Seafoam is just a gimmick.
Old Apr 30, 2025 | 03:15 PM
bruins4ever
I'll see what I can save. My buddy has the scan tool
Old May 1, 2025 | 08:49 PM
Corvette_Dez's Avatar
Corvette_Dez
I read the stuff you post and I'm convinced you're an automotive diagnostic genius!!!!!!!!!! I've reached out to you directly and you've always been a huge help! If you said the sky was red, I'd have to consider it because it came from you!
But Seafoam just a gimmick...
I've performed miracles with that stuff!!!!! Miracles I tell you.
To Rough running issues
