No spark
Old May 3, 2025 | 05:22 PM
CHOPPNLarry's Avatar
CHOPPNLarry
Cruising
Default No spark
So I just installed my SMG flex fuel kit. After starting the engine I started to check cylinder temperature on each header pipe. I found that the coil that is used for the flex fuel kit that cylinder isn't firing at all. I unplugged the flex fuel kit and it fires. Does the ECM need to be programmed for the kit to allow that coil to spark?
Old May 3, 2025 | 06:27 PM
CHOPPNLarry
Cruising
problem all fixed
Old May 4, 2025 | 10:09 AM
pcguy2u's Avatar
pcguy2u
So what was the fix?
Old May 4, 2025 | 10:59 AM
Corvette_Dez's Avatar
Corvette_Dez
Inquiring minds want to know.
To No spark
