C6 keeps stalling
Old May 8, 2025 | 02:06 PM
Schmty's Avatar
Schmty
1st Gear
Default C6 keeps stalling
Air compressor went out, overheated the relay for the air compressor and the fuel pump put a new air compressor in works great switch some relays to replace the ones that got burnt car drives fine it’ll just drive a little while. It’s just everything will shut off and it’ll backfire. I just turned it off. Push the button and start it again and it runs fine. Anybody have an idea what this could be
Old May 8, 2025 | 02:32 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
As a new member it’s ALWAYS a good idea to let us know at least the model year and whatever other information you can tell us…a car that stalls can be a number of things…if you don’t have a scan tool there is not much guidance we can give you…maybe MAF related, MAP, fuel pressure, or crank sensor…if you don’t have a scan tool I’d find a diagnostic shop in your area that can pinpoint it down to one part.
