BTR stage 3 2011 base
Old May 15, 2025 | 07:18 AM
D2207's Avatar
D2207
Default BTR stage 3 2011 base
Hello guys. I have several questions about cam kit.
List of purchased:
  • BTR stage 3 cam kit
  • LS7 Delphi lifters
  • ​​​​​​lifter tray guides
  • 1 to 3 conversation kit (dogbone, chain, ARP bolts)
  • ARP bolt for Balancer
  • thrust retainer plate with arp bolts
  • Che trunion kit, idk arp bolts or not
  • Barbell Oil Diverter
  • By Pass Delete
  • Pickup Tube support
  • All Gaskets for motor (excluding oil pan because it's don't move)
most interesting its about improvement oil system. Barbell Oil Diverter, by pass delete, pickup tube support - is it worth it? Would it really help or destroy motor?
Old May 15, 2025 | 10:07 AM
DarkC-6's Avatar
DarkC-6
The barbell oil diverter is a part that's present in the stock engine. Looks like they put a new one in which is good, but it will not change performance of the oil system at all. Pickup tube support provides additional assurance against the pickup tube loosening, but again will not change performance of the oil system. The bypass delete will prevent the possibility of unfiltered oil from going through the engine.
