I have a C5 with an LS3 swap which is stuck in the garage for a few weeks while I get the headers coated and some issues sorted so I figured it was as good of a time as any to do some upgrades, mainly a cam. The car is used mainly for autocross with some fun weekend drives mixed in. It has a manual trans. Im looking for something with more hp but peak numbers arent quite as important as good power throughout the rpm range.
Brian Tooley recommended their stage 2 cam, and PCM of NC (who is tuning the car) recommended their own custom cut stage 2 as well. Does anyone have any other recommendations or maybe other things that should be upgraded while doing this?
I have that same engine in my C5Z HPDE car and the cam is pretty good for low and midrange power (400 ft lbs of tq at 3000 RPM) while still pulling strong to 6500. The problem with a stouter cam is that you will lose a bit of low end which is critical in Auto X. I'd be inclined to leave the cam alone if the engine is running well. Maybe have your tuner do a few "adjustments" to help the midrange. What rear gears do you have? I know you mentioned running close to redline so stiffer gears may bring a new challenge but that might be worth exploring.
I have been competing for a while with another C5 which had 3.91 gears and I redlined a lot with that. The new car has stock gears I believe so I probably have a 5-10 more mph in the top of 2nd which hopefully will prevent the redlines.
Originally Posted by AllenB
I would not worry about a cam for autox. You have plenty of power. I'd spend money on suspension bits/tires/wheels.
I have pretty much all of that maxed out other than tuning adjustments.
Before you touch the motor,
take car on track and see if you can play rev ranger with the car around the track, or if your playing low rpm grunt master instead.
944 car with turbo spooler, can play rev ranger with the car on autocross and road course tracks all day since there is where the engine makes it power anyway, but with power in the C6, takes a hell of lot of talent to keep back end in check with nannies off and keeping reves high to stay in higher power band instead.
Bluntly, on autocross track, it's bottom end power you want to grunt out of the tight apexes, most will be faster with RV cam that makes power off the bottom, then cam that is going to make all it power top rpm instead.
Simply, run the courses and see where the RPM's are mostly for the runs, and that where where you want to motor to make more power instead.
I would say most of the time I'm between 3k and 5k rpms but since every setup is different, it changes everytime. I do agree though that I want something with a lot of mid rpm grunt and not just a peak hp number!
Alvin and the PCM of NC team are awesome, you're in great hands.
With that said, if it already has the GM hot cam, I would leave it and add 1.8 roller rockers as suggested above. Once those are done, we're talking single digit HP differences between that cam and the others suggested on your setup IMO.
