Technical Dry Sump Oil Change Question
Old Jun 12, 2025 | 10:14 PM
Epitome's Avatar
Epitome
Default Technical Dry Sump Oil Change Question
2010 Grand Sport Coupe Manual Trans. I just changed the oil and followed every step. 10.5 quarts, let the oil heat up to 175 degrees (oil temp, not coolant temp), turned it off, waited 10 minutes……the oil level was right on the middle dot in the middle of the cross hatching marks range on the dip stick. Is this to allow for expansion should the oil get much hotter than 175 degrees? The owners manual warns about filling above the acceptable range. OR should I be adding a little more oil?
So, to be as clear as possible, am I looking to fill to the middle dot (at 175 degrees) or the top dot? The worry is that if the oil gets hotter than 175 degrees and it’s filled to the top dot, it will expand more and cause it to be overfilled. Or am I overthinking this?
Old Jun 12, 2025 | 11:51 PM
djfury05's Avatar
djfury05
You're overthinking it. You're in the perfectly acceptable range at 175° with a short wait.
Old Jun 13, 2025 | 06:43 AM
Spaceme1117's Avatar
Spaceme1117
I always try to shoot for the middle dot with my 2011 GS with the dry sump. So you are good to go.
But anywhere in the range is just fine; bottom dot, middle dot, top dot.
Old Jun 13, 2025 | 08:44 AM
tommyc6z06's Avatar
tommyc6z06
2023 Corvette of the Year Finalist - Unmodified
2022 C6 of the Year Winner - Unmodified
I also shoot for the middle dot @ approx 175~200f.
This translates to almost the top at say 240f (on track), so you don't want to go higher to avoid some of it getting sucked into the intake.
To Technical Dry Sump Oil Change Question
