LS7 Cam sensor wiring
Old Jun 24, 2025 | 08:09 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Default LS7 Cam sensor wiring
So... my AC tensioner failed, causing the belt to come off and it pulled the cam sensor wiring out. From what I see on another thread here, there's supposed to be like a patch harness of sorts:
Well... that's gone. Long gone. No idea where it went. So I need to make a new one. The GM part appears to be discontinued for it.
So my plan was buy two pigtails, spice together on the bench, and presto - problem solved.
I got the part number for the male connector that goes into the cam sensor itself: 12059595 (top half of the wiring in the photo, basically)
But I can't find the female end that goes to the actual harness (bottom half of wiring).
Anybody have an idea?
This is very frustrating. lol
Old Jun 24, 2025 | 11:32 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If you can't find the engine harness connector you can buy any 3 pin male and female connector...may take some depinning and soldering....you can find connectors at mouser.com
Old Jun 24, 2025 | 03:32 PM
Stingroo's Avatar
Stingroo
Update... fixed.
I found this, which apparently is for trucks - but it fits.
https://www.oreillyauto.com/detail/c...or/dch0/645526
And the code is gone. So life is good again. Overpriced? Absolutely. In stock at the local parts store? Also yes.
Win some lose some.
To LS7 Cam sensor wiring
