which spark plugs, when to change?
Old Jun 30, 2025 | 10:20 AM
clearwaterms's Avatar
clearwaterms
Default which spark plugs, when to change?
My 08 has 55k miles and as far as I know the plugs in the car are original. The car runs fine but is used on track regularly and i'm wondering if the next time I spend a weekend doing maintenance i shouldn't add plugs to the list. I changed the plug wires about 8 years ago when one failed so i would probably swap those over as well.
Old Jun 30, 2025 | 11:45 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
AC Delco Iridium plugs would be fine.
Old Jun 30, 2025 | 12:23 PM
Sayfoo's Avatar
Sayfoo
About a year ago, I pulled a plug on a 60k mile '09 and the little tip of the center electrode was eroded/gone. .080" gap. This was the same for 5 of 8.
The funny thing is that other than a slightly rough idle, the car ran fine.
New plugs may have helped the idle, but overall, it ran about the same.
Recently, I changed the plugs on a 70k mile '14, and they still looked really nice.
I think both cars had oem original plugs.
On a c6, it's a fairly cheap and easy job, so I'd at least check a couple of the easy to get out ones.
Old Jul 1, 2025 | 06:26 AM
Spaceme1117's Avatar
Spaceme1117
I know that the stock iridium plugs are supposed to be good for 100K miles. But spark plugs like oil changes are easy to do and are cheap. I would do 25K miles and change the plugs. At most, I would go 50K miles. And I would go with either stock AC Delco iridium plugs are the equivalent in an NGK plug (I cannot confirm but NGK supposedly make the AC Delco iridium plugs for GM).
Old Jul 3, 2025 | 08:11 PM
Kingtal0n's Avatar
Kingtal0n
Iridium plugs at 500-1000rwhp apps seem to last 50k to 80k at 170hp/liter(4-6L V8) and seem to get 13k to 25k miles at 250hp/liter on some customers cars (RB25, 2jz, etc...) with E85 in roll racing apps
To which spark plugs, when to change?
