Help with electric issues
Old Jul 1, 2025 | 01:32 AM
eitanmi's Avatar
eitanmi
2nd Gear
Default Help with electric issues
Hello everyone
I just bought my first corvette it’s a 2007 manual with z51 package
when I bought it I wasn’t checking all the lights and electrical the guy didn’t say anything about later on I found out he disconnected the engine light he did it I guess because of catalytic converter which I care about but this isn’t my real issue
I'm running into an issue with the high bean that’s working just sometime same as the front left turn signal (the back left turn signal flashes fast)
so when the turn signal in front works the high beams also works I checked all the fuses and relays all in great working condition I also checked the light bulbs they’re good and they’re working sometimes but most of the time they’re not I bought it few days ago still trying to figure if it’s happening with the car is hot or no I really need help if some had the same issue or know what should I look for
I’m in the LA area
any help will be appreciated
thank you and have a bless day
Old Jul 2, 2025 | 11:52 AM
SilverC54me's Avatar
SilverC54me
I am down by Disneyland. I can help go through the systems to figure out what may be bad/damaged.
Do you know if the previous owner had modified anything?
Gary
Old Jul 2, 2025 | 12:10 PM
eitanmi's Avatar
eitanmi
2nd Gear
Gary
thank you, I don’t think so it’s mostly stock I’m starting to think it’s the fuse box
Old Jul 7, 2025 | 08:25 AM
Beargo's Avatar
Beargo
Check the ground in that light. Bad grounds cause strange things to happen..
To Help with electric issues
