Trunk key cylinder
Old Jul 10, 2025 | 03:26 PM
SacredC5's Avatar
SacredC5
Default Trunk key cylinder
My trunk key will not turn no matter what I have done. I don’t need it now but I want it to work just in case. It is the correct key and I have cleaned and looked at the release mechanism. Pulling the tab it connects to works perfect. I’ve tried looking but next to none exist in good condition. I’m at a loss. Any ideas?
Old Jul 10, 2025 | 04:18 PM
DarkC-6's Avatar
DarkC-6
Squirt a liberal amount of graphite lubricant in it and try to work it back and forth a bit with the key.
Old Jul 12, 2025 | 07:19 PM
SacredC5's Avatar
SacredC5
didn’t have any luck with that
Old Jul 15, 2025 | 03:19 PM
Dano523's Avatar
Dano523
WD-40, up into the tumblers, and let is sit for a while to allow it to penitrate before you try it again.
Also, could be that old cyclinder was distroyed, was replace with another cylinder that your key is not going to fit. So on that note, look at the plate rivets to see if they look factory or not.
https://www.corvetteforum.com/forums...ylinder-2.html
If not factory rivets, then cylinder plate can be pulled by removing the rivets, and take the cylinder down to a lock smith to have him re-pin it for the oem Vin key.
Old Jul 16, 2025 | 08:14 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I recommended after you have it working properly, you take piece duck tape, use quarter to make perfect circle and tape over the key cylinder to keep dirt clogging the mechanism.
That area gets dirty fast, if you never noticed.
To Trunk key cylinder
