ABS, active handling, traction control.
2007 c6 manual
BACKGROUND: I started getting abs, service traction control, and some active handling that would happen intermittently and when I’m going over small bumps. It sometimes come on, sometimes doesn’t. Disappears after I turn the car off. Most the times I start the car the lights won’t be present and sometimes they will come on, sometimes they won’t.
MY CODES:
C0045: LR wheel speed sensor circuit malfunction
C0050: RR wheel speed sensor circuit malfunction
C0710: Steering wheel position signal malfunction.
C0550: ECU malfunction
C0253: centering fault.
MY STEPS:
-I’ve checked and cleaned both rear speed sensors
- I’ve cleaned all the connector harnesses behind battery on firewall
-I’ve cleared codes and they do come back
-if no codes are present on dash and I scan car the codes still pop.
I’ve checked to make sure wheel position sensor is plugged in.
NEXT STEPS:
-remove battery and check/clean inspect grounds under battery.
- test battery. It is a duralast battery appropriate size from 01/23
-unplug and clean ebcm connector.
Im not worried about the wheel speed sensors or steering position sensor as I can change those. My concern is my ebcm is fried and changing those won’t do a thing. I’m aware of used eBay ebcm and ebcm repair services. Has anyone been in a similar situation? What did you do to resolve this? I’ve looked around forums but everything is a little all over. Any input appreciated
Also not sure if it’s related but sometimes by radio doesn’t power on when I start the car. Replace head unit and it didn’t resolve issue.
It was frustrating because of the intermittent different codes that would pop up.
