Hey everyone, I have a set of c5 wheels laying around and just recently got a c6. My question is what is the process of mounting the c5 wheels onto the c6? Has anyone done on here before? Some insight and information would be much appreciated. Things I need such as spacers and other things. Or can they be mounted directly onto the c6? For reference, the c5 fronts are 255/40/18. Rears are 285/35/19.
I think they will stick out too much.
There's a c5 guy I see around and he has stock c6 rims on his coupe and he has like 2" spacers on but like others said, try them on.
My C6, bought used, came with C5 "wagon wheels". I'm 99% sure all C5's (even the Z) came with 17" front and 18" rears. Mine had no spacers and looked normal as far as spacing goes. Pretty hideous to look at though. Got them off as soon as I could. PO thought the taller side walls of the C5 tires would make it drive smoother. I couldn't tell any difference. Yeah, if you have 18/19" rims, they didn't come from a stock C5.
Yes they are not stock, they are interlagos tsw rims and are slightly bigger. Other than test fitting them, is there any way to tell if they’d fit? Like a size chart of some sort? Or wheel calculator?
thanks for all the replies everyone!
