Corsa Muffler Rattle
Old Aug 18, 2025 | 08:36 PM
C6ytime's Avatar
C6ytime
2nd Gear
Default Corsa Muffler Rattle
Hi all,
I have the Corsa Sports on my C6 and the driver's side has developed a pretty bad rattle sound - video attached. The rattle can even be heard with the car off when you tap around the muffler and shake it. It seems like pressing on the muffler from the bottom or back/front help alleviate the noise...which makes me think some of the internals might be broken. The noise happens at idle, revving and driving. Unfortunately, it's not covered under warranty since it was purchased from a private party. I had a shop check clearances and clamps while it was in getting other work done and it doesn't appear to be coming in contact with anything else.
Has anyone experienced such a thing? What was the fix and were you successful cutting open the muffler?
File Type: mov
File Type: mov
Old Aug 18, 2025 | 09:00 PM
1Hotrodz's Avatar
1Hotrodz
Look for the spot welds on the muffler case, chances are one or more let loose. Without cutting the case, put a self-drilling, sheet metal screw (SMS) thru near the spot weld, not on the spot weld itself as the metal is too hard in that area. Drill a hole first, the size of the major diameter (peak of the threads) of the SMS and then let the self drilling SMS grab the inside metal piece that is loose. If they are stainless steel mufflers, you will have to drill, with a VG drill bit, both pieces of metal with the inner piece drilled for the minor diameter (root of the threads) of the SMS. Stainless is too hard to drill with a self drilling SMS and will just push the inner piece out of the way. This is why I recommend using a good drill bit as opposed to a self drilling SMS. This is only if S.S. mufflers. Actually Stainless Steel is not hard, it just work hardens as you drill it.
Old Aug 19, 2025 | 10:08 AM
PMPerformance's Avatar
PMPerformance
The baffles probably broke off. Mine did the same thing.
If you pull off the muffler, look inside the back for broken baffle chunks.
If you bought them new, Corsa will warrant them supposedly. If you aren’t the original owner, they will tell you to kick rocks and won’t support their product with lifetime garuntee.
Old Aug 19, 2025 | 11:01 PM
C6ytime's Avatar
C6ytime
2nd Gear
Thanks - I'll check the spot welds and see if that's the culprit.
That's my initial assumption. Pretty surprising for such an expensive system. I already got told to kick rocks since I'm not the original owner
Old Aug 20, 2025 | 06:45 AM
PMPerformance
Corsa is not even close to the quality people try and make them to be. If they can’t even fully weld tips on, and have protruding ugly
tailpipes inside the tips, I can’t see why people pay $2500 for these things
To Corsa Muffler Rattle
