2005 differential failures
Thanks!
at 450 it should be fine but at the same time if you keep it up then it will fail
invest in a c5 diff, it will work on an 05 look out the for the rear diff mount makers and easy swap if you’re that concerned. As long as you’re not living a light to light life you’ll be fine
The big one with the later diffs, is GM installed more internal ribs in the case, to make the case itself stronger to begin with..
So not saying that with enough grip and strip prep, your not going to over torque the diff case to blow it up with enough launch G's and no tire spin, or that you can not spin the tires without wheel hope and not be safe (do it all the time to get the back end loose to change lines on the way into apex's when I need to pass someone just before the corner),
But get into wheel hop with even a built diff for the one of the tires to come down hard to over torque bite, kiss the diff good by.
Also note, when you get the back end loose on acceleration, quick way to end up with rear snap hooking on even light tire bite, to crash you out as well.
Hence between suspension and sway bars to keep car level in corner, and diff having LS clutch packs to keep both tires spinning at the same rate, when one of the tires get a bite, its going to cause the back end to really swing out. With the C6, most of the time the back end is going to snap hook out to the right, while on the C7, back end will snap hook out ot the left instead. So know the limitation of what grip you can get with the tires as you are rolling into the throttle, instead of just using the gas pedal like an on/off switch to loose rear end traction wildly instead.
Simply put, the vet is not your dad's pinto station wagon, but a High horsepower sport car that even the base cars will do close to 200mph, that will try to kill you every chance it gets. you skating is past its limit abilities, or your lack of driving talent in a High hp sports instead.
And no, nothing balanced like a 911 or other refined sports cars between HP and handling abilities,
but instead in the C6 up vets, and its gobs more HP that is handling abilities, and why it trying to kill you every chance it gets/any driving mistake you make instead.
New to the forum. I’ve got a 2005 c6 manual (3.42 gear ratio). Getting ready to put a C5 diff on and when we got it up on the lift, noticed that the one on it, was not the original. Called the previous owner, and he verified that when he bought it, the diff had just been replaced. That was about 3 years ago. My question is, is there a way to know what year car this came off of? SURELY, anyone that went to the trouble to replace the rear end would not replace it with another weak one off an 05’. But, people do crazy stuff! I’d like to confirm that what’s currently on it is a 06’+ or maybe even one from a C5. Where are the ID numbers located on the differential itself? I’ve read so much about this that it’s all running together! Is there a way to know what year car this came off of, and if so, where is it stamped?
