Front wheel bearing failure
Old Sep 24, 2025 | 11:26 AM
Rob Via's Avatar
Rob Via
Default Front wheel bearing failure
I replaced the front left wheel bearing when I bought the car. Now 3 years later and only 7k miles, it has failed again. I used a Timken as I thought they were good bearings.
Could something else be causing the bearing failure? I don’t have alignment issues that I know about.
What is a good bearing?
Did I just get a bad bearing? I know it happens, but it sucks when it happens to you.
Old Sep 24, 2025 | 01:56 PM
BadAV's Avatar
BadAV
Last I knew, Timken was about as good as it gets. Who knows today, with almost everything coming from China. Maybe OEM?
Old Sep 25, 2025 | 07:47 PM
on track's Avatar
on track
Do you have aftermarket rims and/or wheel spacers?
Old Sep 25, 2025 | 09:18 PM
Rob Via's Avatar
Rob Via
I do have aftermarket wheels. I put new tires on around the time I did the bearing. I’ve never had any vibration. No spacers.
Old Sep 26, 2025 | 10:32 AM
JCMDoug's Avatar
JCMDoug
I moved away from Timken a few years ago due to folks coming back with issues, (I run a small shop from home on the side). They only have a 12 month warranty while others like SKF and Mevotech have 5 years 60k.
Acdelco is two years unlimited miles. Timken has the same warranty as $40 ones at Rock Auto.
Old Sep 26, 2025 | 01:24 PM
Rob Via's Avatar
Rob Via
Interesting. The Mevotech are $50 and the Timken are $150. SKF are in the middle.
Old Sep 26, 2025 | 06:15 PM
Corvette_Dez's Avatar
Corvette_Dez
Timken used to be great, but also used to be made here. FM and others use to be great too. Now it's a craps shoot with any brand.
Old Sep 27, 2025 | 09:50 PM
vetteJPJ's Avatar
vetteJPJ
I've changed the bearings all around several times over the last 150K. Got Moog bearings the last time (22K so far). They are quiet and work.
Old Oct 1, 2025 | 07:43 AM
rentedmule's Avatar
rentedmule
The SKF X-tracker hubs are the gold standard for track cars. I don't think any other brand comes close.
To Front wheel bearing failure
