Pushrod Length
Old Sep 26, 2025 | 06:52 PM
Aidenc's Avatar
Aidenc
Default Pushrod Length
Put in a stage 3 cam, upgraded rocker roller andlifters. Having trouble getting pushrod length right.Put in hardened 7.4" rods, stock length, dependingwhat valve Spring is compressed one or tworockers will have up and down play. First rocker shown has adjustable 7.425" rod and play is quite minimal, compared to the stock one that has play. Should I go ahead and get the 7.425" rods? The rest are tight and only have side to side play
https://youtu.be/OV7LSZ1jdxw
Old Sep 27, 2025 | 06:33 PM
ringram's Avatar
ringram
Ideally get an adjustable pushrod and measure them. It does not take that long. Then you can order whatever size suits.
Old Sep 27, 2025 | 07:27 PM
Aidenc's Avatar
Aidenc
Yeah I think that's the route I'll go
Old Sep 27, 2025 | 08:26 PM
davidfarmer's Avatar
davidfarmer
it only matters when you are on the base circle
Old Sep 27, 2025 | 08:37 PM
Aidenc's Avatar
Aidenc
Okay, I'll double check some measurements from base circle to see how it looks, I think the stock 7.4" length should be within the 30-50 thousands preload
Old Sep 29, 2025 | 08:13 PM
Aidenc's Avatar
Aidenc
How does this look? Adjustable pushrod set to 7.45" torqued, seems like the right amount of play, no up and down movement without lots of force
Old Oct 1, 2025 | 09:32 PM
JL3100AD's Avatar
JL3100AD
Looks good, just a little side to side wobble so you know it's not too tight and bound.
To Pushrod Length
