'07 transmission issues
Old Sep 29, 2025 | 12:13 PM
Crispy83's Avatar
Crispy83
5th Gear
Default '07 transmission issues
So i have a '07 base automatic, was shifting funny at times but never did it consistently. I checked it with my scan tool and it had a "P0989 Transmission Fluid Pressure Switch 5 Circuit Low Voltage" code. Google tells me it is most likely the little plastic wafers in the TCM. So i order replacements and tore into it on Saturday. Two of the discs were torn/broke. Got everything back together, did a TCM reset and went for a short test drive, upper gears seems to shifting just fine, but from a stop, if i apply anything more than a feather the trans slips and bangs into gear. If i feather it the trans does fine, and shifts like normal. This problem did not exist before i replaced the plastic wafers. Is this a pressure issue that will go away with the learning, or is it time for me to take it to a transmission shop?
Old Sep 30, 2025 | 10:23 AM
C6VetteLover's Avatar
C6VetteLover
Did you clear the codes?
