C6 Fuel Pump Upgrade Help
Old Oct 13, 2025 | 10:08 AM
mfsr's Avatar
mfsr
Cruising
Default C6 Fuel Pump Upgrade Help
Hey everyone, I’m looking for some advice on what the best in-tank fuel pump is for a C6 making around 550 rwhp. I’ve been leaning toward the Lingenfelter C6 High-Flow Fuel Pump Module, but I can’t seem to find many real reviews or feedback from people actually running it. I’ve also looked into the Racetronix 450, but I’ve read quite a few negative reviews about reliability and pressure issues. I really don’t want to go with an external fuel pump setup, so I’m hoping to hear from people who have experience with either of these or have other solid in-tank options to recommend. Any input on their performance and reliability would be greatly appreciated.
Old Oct 13, 2025 | 10:26 AM
kkupec02's Avatar
kkupec02
Welcome!! Someone here will be able to help.
Old Oct 13, 2025 | 10:31 AM
Moved to C6 Tech for help.
Old Oct 13, 2025 | 11:10 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
welcome
Old Oct 14, 2025 | 12:23 AM
djfury05's Avatar
djfury05
Stock Z06 pump will be more than enough for 550rwhp.
This is all you need,
https://www.racetronix.biz/k/c5-c6-2.../rfpk-475-450e
Old Oct 14, 2025 | 08:19 AM
double06's Avatar
double06
I agree with guy above stock Z06 pump is all you need and you do not need to rewire it. Any pump with substantially more flow you will need to run a new power wire to it. The stock Z06 pump flows like 10%-15% more than the regular pump. The Z06 pumps takes 11 amps of current the other bigger pumps are in the high teens and thus need a bigger wire/fuse. Also be wary of the tank level sensor 2003-2006 had one ohm reading 2007 and later had another.
Old Oct 14, 2025 | 09:13 AM
mfsr's Avatar
mfsr
Cruising
I have a ls3 2008 corvette with the a&a supercharger. I currently have the racetronix hotwire harness installed with a boost a pump and im looking to take the boost a pump off and just have a normal fuel pump that can handle my supercharger
Old Oct 14, 2025 | 10:03 AM
DarkC-6's Avatar
DarkC-6
I would definitely consider the racetronix 450 drop-in pump. Since you already have the hotwire harness installed, you just need to add the intermediate pump harness when dropping your tank to fully upgrade your wiring.
https://www.racetronix.biz/p/c5-6-co...arness/iph-008
Old Oct 14, 2025 | 04:53 PM
mfsr's Avatar
mfsr
Cruising
Do you have it or know anyone who has them i read they have a lot of issues with pressure and go out pretty fast
Old Oct 14, 2025 | 04:55 PM
DarkC-6's Avatar
DarkC-6
No but you have me wondering now. Got any details?
Old Oct 14, 2025 | 08:03 PM
djfury05's Avatar
djfury05
Why? Boost-a-pumps are perfectly acceptable additions and hardly ever fail. Unless something is amiss here I think the classic case of don't fix it unless its broken applies.
I have the Racetronix link above with Kenne Bell Boost a pump, A&A supercharger, 80lb injectors with heads/cam making 770 rwhp and have no concerns.
Old Oct 15, 2025 | 05:17 AM
mfsr's Avatar
mfsr
Cruising
My boost a pump fried my fuel pump 2 times and i rather get a permanent fix that doesn’t even have the chance for that to happen again.
Old Oct 15, 2025 | 05:31 AM
mfsr's Avatar
mfsr
Cruising
https://ls1tech.com/forums/fueling-injection/1959116-racetronix-fuel-pumps-garbage.html
https://www.corvetteforum.com/forums/c6-corvette-general-discussion/4623343-anyone-using-a-racetronix-walbro-450-fuel-pump-assembly-also-not-holding-pressure.html
Old Oct 15, 2025 | 07:18 AM
DarkC-6's Avatar
DarkC-6
That doesn't sound right. Was it hooked to a hobbs switch so it only activated during boost? 99% of the time while driving the fuel pump booster should not be active.
Old Oct 15, 2025 | 10:06 AM
djfury05's Avatar
djfury05
Yea something aint adding up here. To have one failure is very rare but to have two... something else going on.
Old Oct 15, 2025 | 03:44 PM
mfsr's Avatar
mfsr
Cruising
Yea i got it with the a&a supercharger kit and i had a professional shop that specializes in corvettes and superchargers put it on for me
Old Oct 15, 2025 | 05:09 PM
djfury05's Avatar
djfury05
Have you spoke to the shop about it?
To C6 Fuel Pump Upgrade Help
Old Oct 15, 2025 | 05:55 PM
mfsr's Avatar
mfsr
Cruising
They just recommended me replacing my fuel pump with a walbro 450 in the stock bucket when i talked about it
Old Oct 15, 2025 | 09:36 PM
MARSC6's Avatar
MARSC6
I went this route https://ecsgarage.com/products/ecs-s...to-13-corvette
Old Oct 15, 2025 | 10:11 PM
mfsr's Avatar
mfsr
Cruising
Originally Posted by MARSC6
I am thinking of buying that kit, how long have you had it on your car and have you had any issues?
