Flat tire notification on Run Flat
Old Oct 16, 2025 | 03:28 AM
Vets Vet 80's Avatar
Vets Vet 80
Navigator
Default Flat tire notification on Run Flat
On my 2006 c6 I bought new Firestone Firehawk Indy 500 NOT run flat tires. Getting a flat tire notification for the rear left. Tire pressure is fine. Could this be due to a faulty TPMS ?
Old Oct 16, 2025 | 07:34 AM
rentedmule's Avatar
rentedmule
The battery in the pressure sensor on the wheel is likely dead.
Old Oct 16, 2025 | 07:35 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
How old are your TPMS, if you get false reading XXXX means the battery is dead, if shows low reading, and pressure is good, that's warning you might need to replace it.
When I had false reading I replaced all 4 when, if 1 is going others will follow.
To Flat tire notification on Run Flat
