Idle down issue
Old Nov 17, 2025 | 05:11 PM
gjs525's Avatar
gjs525
Cruising
Default Idle down issue
c6 / 6 speed: @ stop light when I depress clutch, engine rpm hesitates for 10-12 seconds @1100 rpm then reduces to idle @ 750-800. We have cleaned MAS & Throttle Body. - any other ideas
annoying but still very drivable
Old Nov 17, 2025 | 10:48 PM
ringram's Avatar
ringram
OEM setup?
If not, then likely tune airflow model needs adjusting
If its OEM, then check for vac leaks etc. Rear brake vac line, manifold seals etc,
