Dollar bill test
Old Nov 20, 2025 | 09:52 AM
Coopaloop388's Avatar
Coopaloop388
4th Gear
Default Dollar bill test
Hi all so I was roaming around online and came across the dollar bill, or 5 or paper to see if you have bad exhaust valves. So stupid me I tried it on my 08 C6 with 20,000 miles. It does suck in a little if I push the bill in closer. Is this true ? Now I am all worried. Thank you
File Type: mov
Old Nov 20, 2025 | 11:01 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Not necessarily just a bad exhaust valve...any type of misfire can cause the dollar bill to get "sucked back" into the tailpipe when there is no combustion process...watch the video from about the 4:30 mark....better to use a factory level scan tool to see if you actually have a misfire.
Old Nov 20, 2025 | 03:53 PM
Spaceme1117's Avatar
Spaceme1117
There is nothing wrong with your car.
Drive and enjoy your car as stop worrying.
Old Nov 20, 2025 | 04:20 PM
Coopaloop388
4th Gear
thank you
Old Nov 20, 2025 | 04:22 PM
Coopaloop388
4th Gear
https://youtu.be/D0LXtvY3Qdg?si=Oj_UrI4yowhgXcD2
cool video, I don’t have a misfire. And I don’t think the bill is getting sucked in like the old school test . That would be like actually sucking it in the tail pipe ?! Plus with an X pipe not sure if it’s valid
Old Nov 20, 2025 | 06:37 PM
C5 Diag's Avatar
C5 Diag
If you don’t have a misfire it won’t get “sucked in”.
To Dollar bill test
