C6 cold weather door lock & start problems
getting to check your battery starter and alt is a good idea and adding a big kit for good panache won't hurt.
INFORMATION
Bulletin No.: 10-08-52-004
Date: October 04, 2010
Subject: Diagnostic Information on No Remote Detected or No Fob Detected or No Fobs Detected Message on DIC / Electrical Interference with a Cell Phone, MP3 Player or Other 12 Volt Charger Plugged In
Models:
2010-2011 Buick LaCrosse
2004-2009 Cadillac XLR
2005-2011 Cadillac STS
2010-2011 Cadillac SRX
2005-2011 Chevrolet Corvette
Condition
Some customers may comment about a temporary no start condition with a "No Remote Detected" or "No Fobs Detected" or No Fob Detected" message on the DIC.
Electrical Interference Concern
Certain brands of cell phone chargers may produce electromagnetic interference (EMI) or radio frequency interference (RFI) that can disrupt the electrical systems within the vehicle. This interference may cause a no start condition with a "No Remote Detected" message on the DIC. The interference created by the use of these chargers may be intermittent and random. The concern may be present with or without the phone connected to the charger.
Disconnect the cell phone charger from the vehicle and evaluate the customer concern. If the concern is corrected, advise the customer that OEM cell phone chargers, provided by the cell phone manufacturer, typically have additional filtering to eliminate this type of interference. Avoid the use of low quality charging devices.
Notice
This type of interference may be encountered with charging devices for cell phones, MP3 players, GPS units, DVD Players, etc. The device does not need to be plugged into the charger to create this interference, only the charger need be plugged into the 12 volt power point of the vehicle. Moving the key fob away from the charger as far as possible may correct the condition.
Important
Placing the transmitter in the transmitter pocket (found in the console storage area or I/P storage compartment on Corvette/XLR) will allow the vehicle to start even under interference conditions.
# PIC5961: NO FOB DETECTED Message On DIC Possible No Crank Start - (Feb 4, 2014)
Subject: NO FOB DETECTED Message On DIC Possible No Crank Start Models: 2004 - 2009 Cadillac XLR 2005 - 2013 Chevrolet Corvette
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
Some customers may comment of a "NO FOB DETECTED" message when attempting to start the vehicle. Vehicle may not crank/start and the vehicle's doors may not open through passive entry. However, the vehicle will always start when the fob is placed in the IP compartment pocket. This concern may be the cause of a transistor that is internal to the RCDLR module not operating properly.
Recommendation/Instructions
1.Be sure the vehicle battery is adequately charged to start vehicle.
2.Remove the battery from the key fob / transmitter. Using a DVOM, measure the voltage. Be sure the key fob battery voltage is between 2 to 3 volts. If not, replace the battery. Test operation of the vehicle again prior to moving on to step 3. If the vehicle no longer exhibits a concern, the vehicle is repaired. If the vehicle still has a concern, proceed to step 3.
3.While in the vehicle with a known good fob (not placed in the IP compartment pocket), press the Start Button. Listen for a click noise or a series of click noises from the RCDLR. If there is only ONE CLICK (instead of a series of clicks), then the transistor internal to the RCDLR is not operating properly. For this condition, replace the RCDLR module with current GM CCA stock.
RCDLR module locations are listed below.
- The Corvette RCDLR is located above the radio behind the IP trim on the right side.
- The XLR RCDLR is located on the top right of IP under upper IP pad.
Open In New Tab Zoom/Print
Warranty Information
