Front Camera Wire Routing?
Old Dec 22, 2025 | 03:29 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Front Camera Wire Routing?
I have an aftermarket Head unit ( currently iLx-507) I am installing a front camera. The camera is mounted, I have dropped the hush panel on the passenger side and looking for a good spot to run the wires. I need to be able to pull the RCA through the firewall. I am looking for some suggestions as to where to run it through? also any tips as to how you did it.. Pictures of the location will be helpful.
I know I need to pull the battery to gain room, so want to have the plan laid prior to running the wires..
Side note, I have a future plan/idea of running a 4 Ga wire for a couple amps if I decide to fully do the audio system.. so spots for that would be helpful too..
Thanks for any info you can provide.
Old Dec 23, 2025 | 10:08 AM
woodsdesign's Avatar
woodsdesign
Following as I also want to run a front camara and also have a iLx-507
Old Dec 23, 2025 | 12:45 PM
DarkC-6's Avatar
DarkC-6
Once you pull the battery you will see behind it a factory wire harness passing through a grommet that you can run the wires through. It will come in just above and right of the kick panel fuse box.
Old Dec 23, 2025 | 02:18 PM
-=Jeff=-'s Avatar
-=Jeff=-
I assume there is enough flex to run the wires through the same opening the harness is passed through and I don't need to make a separate hole in the grommet
Old Dec 23, 2025 | 02:29 PM
DarkC-6's Avatar
DarkC-6
You will need to poke a new hole or pop an edge of the grommet out to push it through.
Old Dec 23, 2025 | 05:26 PM
Aardwolf's Avatar
Aardwolf
Yes that's what I did too and used black rtv to seal it.
Old Dec 25, 2025 | 12:57 PM
-=Jeff=-'s Avatar
-=Jeff=-
Thanks for the picture. Also how did you get the battery tray off? I had what looked to be all the bolts out of it, but it seemed stuck, I need to fix the battery hold down nut..
Old Dec 25, 2025 | 04:52 PM
Aardwolf's Avatar
Aardwolf
There are four bolts one on each side with the head on the inside of the tray. Then it will slide up and off with some rocking back and forth.
Old Dec 25, 2025 | 07:45 PM
-=Jeff=-'s Avatar
-=Jeff=-
hmm, I saw 3 bolts the last time, next time I will look closer.. thanks
To Front Camera Wire Routing?
