Upgraded Fuel Pump/Lines Proper Layout?
Old Dec 26, 2025 | 03:46 PM
Rino1425's Avatar
Rino1425
Default Upgraded Fuel Pump/Lines Proper Layout?
I have a Chris 1313 tophat with new pumps I am installing and running new AN lines. With doing this I am also going to a return style and an adjustable FPR. My plan is to split the main -10 line into the 2 -8 lines to go into the back of the FAST fuel rails. The fronts, I was going to connect and mount the FPR with a -6 bottom return line. I dont think I will have the space I wanted to do this, so rethinking how I am going to run it. My understanding is that the FPR should be at the end of the line with the return. Is that correct? Or do I have that backwords and it needs to be before it goes into the fuel rails. Any help on this or pictures of where others have mounted the FPR is greatly appreciated
