2007 corvette grinding sound
Old Apr 22, 2026 | 08:06 PM
LaneMiller's Avatar
LaneMiller
1st Gear
Default 2007 corvette grinding sound
When I push in the clutch I hear a grinding sound coming from the front half of the car and I can’t figure out what it could be does anyone have experience with this issue ? It doesn’t get worse with rpm only on clutch press.
Old Apr 22, 2026 | 08:09 PM
NORTY's Avatar
NORTY
Welcome to the site.
Old Apr 23, 2026 | 10:40 PM
torquetube's Avatar
torquetube
Probably a failed pilot bearing, which will have worn out the end of the input shaft. The fix takes identical labor as a complete clutch job, so you might as well do that, plus at least a partial torque tube rebuild to address the input shaft.
To 2007 corvette grinding sound
