SCHRADER 29180 relearn issues
Old Apr 25, 2026 | 11:00 AM
Jeep43's Avatar
Jeep43
Default SCHRADER 29180 relearn issues
I have an 05 and bought new wheels and based on recommendations on this forum, Shrader 29180's which are supposed to be pre-programmed, just needing to follow the cars relearn procedure to pair.
https://www.rockauto.com/en/moreinfo...pt=12036&jsn=3
I just unboxed them and mounted in the wheels and wanted to confirm the would learn by enabling the relearn procedure and zapping them with my EL-50448 tool before tires get mounted. No dice.
I then scan my other set of wheels and they are recognized just fine like they have in the past. Do these schraders need some sort of initialization? Like a battery tab removal to energize them? Do they need to see pressure to work? Do I need to clear out the old TPMS from the car somehow?
Old Apr 25, 2026 | 03:30 PM
Jeep43's Avatar
Jeep43
Turns out I have a dud. The first one I tested doesn't read but when I eventually go around to try the others they do......
Maybe a 433mHz unit misboxed.
My luck.
Old Apr 25, 2026 | 06:39 PM
crusher1's Avatar
crusher1
Bad battery on the dud maybe. Whats the date code on that bad TPMS
To SCHRADER 29180 relearn issues
