Input on spring pressure for ls3 stroker
Old Apr 30, 2026 | 01:48 PM
hearno's Avatar
hearno
Default Input on spring pressure for ls3 stroker
I'm seeing an issue with power rolling off early, 6300 rpm. Car's on a hi-ram, no air restriction on intake side, heads are capable of moving a lot of air also. I'm thinking it's a spring pressure/valve float issue. Anyone able to share a recommended spring pressure for an ls3 based 417 stroker that's at about 13:1 compression and spinning to 7400 or so? Cam is:
In./Ex. Duration242/258
In./Ex. Valve Lift
.646/.637
Old May 1, 2026 | 09:22 PM
hearno's Avatar
hearno
bump
Old May 6, 2026 | 08:57 PM
hearno's Avatar
hearno
bump
Old May 7, 2026 | 08:07 AM
double06's Avatar
double06
What springs are in there now? I presume steel valves how about rocker arms GM or adjustable or roller tip ones etc. What lifter do you have in the motor - OEM, Johnson regular - limited travel etc. Pack 1207x might be an answer but we need to know the details here. The 1207x is a 155 / 450 or so on the nose.
Old May 7, 2026 | 09:24 AM
hearno's Avatar
hearno
thanks for checking in. springs in now are btr .660s. yes, 110g (i think) stock valves from ls 823 heads. btr shaft mount rockers, lifters are caddy racing. i had considered the 1207x and the 1209x and the psi 1513ml. looking at btr .685s also.
Old May 10, 2026 | 12:56 PM
hearno's Avatar
hearno
bump
To Input on spring pressure for ls3 stroker
