Harmonic balance wobble
Old May 15, 2026 | 08:51 PM
BET VETTE's Avatar
BET VETTE
Default Harmonic balance wobble
How often are they and what sound does it make
Old May 15, 2026 | 09:20 PM
NORTY's Avatar
NORTY
They don't make much noise, but they're easy to examine, if you lean over the passenger fender and watch it, when the engine is running. If you see it move at all, then it's not a bad idea to replace it with a quality aftermarket unit. (An "underdrive" unit isn't advised if you want you're A/C to be as good as it was previously.)
If you replace it with an OEM unit, expect to replace it again, down the line.
Old May 15, 2026 | 10:01 PM
BET VETTE's Avatar
BET VETTE
I was looking at one at a dealership and heard a on and off whining sound but the engine was running smooth and the ac was ice cold
Old May 16, 2026 | 07:14 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
If I was you, get it check, mind made whining noise, sorry to say ignored till decided to do thousand of dollars to damage, destroying my A/C compressor crank pulley lot more.
Get it checked if asked you must be concerned so get it checked for peace of mind.
Old May 17, 2026 | 08:15 AM
BET VETTE's Avatar
BET VETTE
I went back and took a look at the harmonic balance and it was wobbling. The dealer said he can take off $1000 if I like
Old May 17, 2026 | 11:43 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
Replacement of the HB by a reputable Corvette specialty shop runs around $2K to $2.5K...at least here in the NJ area. Make a counter offer to discount by that amount. If the wobble is obvious, as it sounds lie it is, you will need to have the replacement done. And DO NOT use the GM OEM pulley....use PowerBond or ATI.
Old May 17, 2026 | 03:33 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
I would pass, or have them replacement part, cause more then likely when a tech gets into, he will find more problems then simple costly replacement.
Old May 17, 2026 | 09:00 PM
BET VETTE's Avatar
BET VETTE
From what I’ve been reading it going to go on the wack anyway
To Harmonic balance wobble
