C6 Random engine shutoff issue
Old May 22, 2026 | 10:00 PM
Corvette_Dez's Avatar
Corvette_Dez
Originally Posted by C5 Diag
You can go to the PicoScope website and download the software and use it in "demo mode"...there are many Youtube videos on its use.
Sweet! I'll be diving in after I receive it.
Old May 22, 2026 | 10:23 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
You should buy yourself some back probes and a low amp clamp and a high one if you can afford it !!
Old May 23, 2026 | 02:05 PM
C5 Diag's Avatar
C5 Diag
You can pick up a cheap 5 drawer toolbox from Harbor Freight and start putting together your own diagnostic cart...I'm using a 43" monitor for the labscope.
Old May 23, 2026 | 02:18 PM
Corvette_Dez
I love your setup. I've got the tool boxes covered. I like the big TV for a monitor.
I was going to use my laptop, but I may just use build a dedicated pc and use a spare tv I have for a monitor.
Old May 23, 2026 | 02:24 PM
C5 Diag's Avatar
C5 Diag
Mine is not a TV but just a cheaper monitor...I have an HDMI cable from my laptop to the monitor...I mounted the monitor on the lid.
Old May 25, 2026 | 11:05 AM
Beargo's Avatar
Beargo
Originally Posted by C6Esus
I recently purchased an 05 C6 ls2 base. I experienced a random shutoff while my car idled for about 2 mins. electronics stayed on , i then drove it home for about 7 mins, experienced two shutoffs , both gave me the "shift to park" message my dash stayed on however my engine cut off. I then scanned my car for codes & got a lean on banks 1 & 2. Mind you no CEL. I then took it my local shop & they recommended changing my MAF sensor. This could possibly be responsible for my shutoffs. We had then changed the MAF. Codes cleared. Nothing came back. After a week or so after driving i experienced another shutoff. dash still lit. mind you i have no experienced any other weird things with the car and the car still scans for ZERO codes. Looking for recommendations or suggestions.
My C6 does that now and then, I get the "shift into park" reading, I just push the shifter forward and the lights go out. I need to adjust my shift cable to fix it , soon as I get off my lazy butt to do it.
Old Jun 4, 2026 | 02:32 PM
Smokehouse00's Avatar
Smokehouse00
The lean code shows that it had a lack of fuel. The problem is either the fuel pump relay is going bad. Or the fuel pump relay pins in the fuse box are not getting good connection. Super common on the C6. I had this
same issue. My fix was to tire in to wire up a whole new relay and positive wire to the fuel pump. There is a harness infront of the driver rear wheel in behind the liner hat goes to the pump. I tied into the system there.
