Actual specs from chevy.com INCLUDES WEIGHT COMPARISON!
Old Jan 4, 2004 | 09:14 PM
Beaz's Avatar
Beaz
Default Actual specs from chevy.com INCLUDES WEIGHT COMPARISON!
Here are the "official" specs from chevy.com
CORVETTE SPECIFICATIONS (2005 VS. 2004)
2005 COUPE 2004 COUPE
Overall length, in. 174.6 179.7
Overall width, in. 72.6
73.6
Overall height, in. 48.7 47.7
Track, F/R, in. 62.1/60.7 62.0/62.1
Coefficient of drag Less than .29 .29
Curb weight, lb. 3,179 3,246
Engine 6.0-liter LS2 V8 5.7-liter LS1 V8
Bore x stroke, in. 101.6 x 92.0 99.0 x 92.0
Horsepower @ rpm
400@6000 350@5200
Torque, lb.-ft. @ rpm 400@4400 360@4000
Wheels, F/R 18 x 8.5/
19 x 10.0 17 x 8.5/
18 x 9.5
Tires, F/R 245/40ZR-18/
285/35ZR-19 245/45ZR-17/
275/40ZR-18
:steering:
Old Jan 4, 2004 | 09:16 PM
GDP's Avatar
GDP
Default Re: Actual specs from chevy.com INCLUDES WEIGHT COMPARISON! (Beaz)
:cool:
Old Jan 4, 2004 | 10:13 PM
Tiger Shark's Avatar
Tiger Shark
:thumbs:
Old Jan 4, 2004 | 10:46 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
:cool: :cool:
Old Jan 4, 2004 | 10:49 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
so it IS 67 lbs lighter? Wow! That's better than what we've heard in last few weeks. :cheers: :party:
Old Jan 4, 2004 | 11:10 PM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
Part of the weight saving was using one less quart of oil. :jester
Old Jan 4, 2004 | 11:14 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
HA!
(Not that I'm going to rub it in every chance I get.)
Old Jan 5, 2004 | 12:01 AM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Actual specs from chevy.com INCLUDES WEIGHT COMPARISON! (Another Yellow)
And the material removed in the console for the 2nd cup holder.
Old Jan 5, 2004 | 01:49 PM
Z-Rated's Avatar
Z-Rated
The reason the C6 is quoted at 48.7 " (+1") is because this dimension included the XM Band Antenna. The C6 and C5 are actually the same overall height at 47.7" according to Corvette Quarterly.
:cool: :cool: '''''' :cool: :cool:
Old Jan 5, 2004 | 02:17 PM
LongTimer's Avatar
LongTimer
Default Re: Actual specs from chevy.com INCLUDES WEIGHT COMPARISON! (Z-Rated)
That weight looks very encouraging!! I really hope it is the weight at which most of us will see our C6s delivered. However, this is an area where I pick nits. Parity is crutial here lest we be duped. I'd very much like to know how the 3179 lb C6 was equiped. The RPO shows a 1SX option that is stripped of door airbags, HUD, memory - the most popular options. My guess is this is that I'd like to see the weights of C6 vs C5 both with Z51, 6sp M, and 1SB options and transparent top. That, or something pretty close to it, is how most of the C6s will be sold IMO. Likewise, is the 3245 lb C5 "stripped" or equipped?
Old Jan 5, 2004 | 03:18 PM
Dsob15's Avatar
Dsob15
Default Re: Actual specs from chevy.com INCLUDES WEIGHT COMPARISON! (LongTimer)
That bigazz steering wheel couldn't of helped the weight. :lolg:
Old Jan 5, 2004 | 04:50 PM
SWCDuke's Avatar
SWCDuke
Published curb weights are for "base" models and there will also eventually be published info on option weights.
Since the C6 base model now has a manual rather than automatic as on C5 there is probably some saving there as manuals are usually ligher than autos.
When magazines test cars they usually weight the car with full fluids, including fuel, so we get a report on the curb weight for the specfic test vehicle including whatever optional equipment it has.
Another alternative to reduce "road weight" is for owners to go on a diet and lose some the the extra pounds that a lot of them are carrying around. ;)
Duke
Old Jan 5, 2004 | 05:02 PM
LongTimer's Avatar
LongTimer
Default Re: Actual specs from chevy.com INCLUDES WEIGHT COMPARISON! (SWCDuke)
Duke
:thumbs: I hear that. I lost 17lbs in '03 and plan to drop about 10-15 more!
Old Jan 5, 2004 | 05:07 PM
LongTimer's Avatar
LongTimer
Where will we find this? ...on the GM site? I don't recall seeing this on the C5, but I probably didn't know where to look.
Old Jan 5, 2004 | 09:08 PM
need-for-speed
CI 1-4-5-8-9-10 Vet
Exactly. I'm sure the C5 that the C6 mass was compared to was the stripped base model as well. Both models are strippers, therefore, the comparison IS apples to apples. The delta is valid
p.s. I lost 20 lbs in '03 as well, but I found 5 of them over the holidays :lol:
[Modified by need-for-speed, 8:11 PM 1/5/2004]
Old Jan 5, 2004 | 09:49 PM
SWCDuke's Avatar
SWCDuke
The AMA/MVMA specs that GM hands out to vintage Corvette owners as part of their complimentary "restoration package" includes weight deltas of all the options. I expect that similar data is published today, but it not generally released to the public, however, and enterprising person can probably find it.
At 6' and 190 pounds I'm about the same as I was 20 years ago, but I try to wear light shoes when I drive. ;)
Duke
Old Jan 6, 2004 | 10:30 PM
Bobby J's Avatar
Bobby J
Default Re: Actual specs from chevy.com INCLUDES WEIGHT COMPARISON! (need-for-speed)
The C6 has that 1sx package that is supposed to be a stripper, something not available for the non-Z06 C5. Also, the transmission for the base C6 is a manual, while the base for the C5 was an auto. Autos are usually heavier than manuals. I'm sure they used the lightest model to publish numbers for. Until we see what the packages include and how much each weighs, it's hard to compare apples to apples and see what kind of weight losses where achieved by engineering, and not just by removing options and making a manual standard.
To Actual specs from chevy.com INCLUDES WEIGHT COMPARISON!
Old Jan 6, 2004 | 10:43 PM
need-for-speed
CI 1-4-5-8-9-10 Vet
Default Re: Actual specs from chevy.com INCLUDES WEIGHT COMPARISON! (Bobby J)
you make some very good points w/ the 1sx and MN6 being std :thumbs:
SWC.....looks like you've done a good job of staying at your ideal weight :cheers:
If I could just stay away from fried pork chops and chocolate chip cookies :lol:
Old Jan 7, 2004 | 12:31 AM
LS1LT1's Avatar
LS1LT1
Well, there basically was a base model C5, '1SA't', is essentially the 'stripper' model and the base C6 should be equipped the same way no?
Old Jan 7, 2004 | 03:00 PM
Bobby J's Avatar
Bobby J
Default Re: Actual specs from chevy.com INCLUDES WEIGHT COMPARISON! (LT1LS1)
I think the C6 as a 1sa model as well. I've never seen the t added to the end, so I don't know what that includes. I would think the C6 1sa would be comparable to the current 1sa. We will have to see the list to know for sure.
