5.7 to 6.0 - is it a 355?
I need some help understanding this. Did they bore out the 5.7? An engineering dude told me of some conversion based on cam rotation or something - multiply the liters by 6 to get cubic inches? I get 360, so that can't be right. Or is it?? :seeya
Received 1,974 Likes
Re: 5.7 to 6.0 - is it a 355? (jmrl98)
101.6mm by 92.00mm = 5.9670L x 61.025 = 364.14 cubic inches
The LS1/6 have a bore of 99mm. The LS2 bore and stroke are now the same as the cast iron truck engines. GMPT reduced the bore of LS1/6 because of the liners. The bores are now siamized (no coolant running between the cylinders), so they could go with a full 4" bore.
Duke
[Modified by SWCDuke, 9:07 AM 1/5/2004]
[Modified by SWCDuke, 10:37 PM 1/6/2004]
Duke
Re: 5.7 to 6.0 - is it a 355? (SWCDuke)
Duke
Duke
Todd
Re: 5.7 to 6.0 - is it a 355? (LittleBoyBlu99)
It's NOT 366. It's 364 CID. Run the numbers - 101.6mm bore; 92.00 mm stroke or read the entire thread.
Duke
Duke
Cruise-In II Veteran
Cruise-In III Veteran
Re: 5.7 to 6.0 - is it a 355? (jlcvt)
"366" sounds good :) but "427" sounds better :hurray: :steering:
Regarding the displacement, for exact precision (of course depending of the length of pi used):
pi(r^2)h = volume of cylinder
3.14159265(2^2)3.62 = 45.490261572 ci
45.4672 x 8 cylinders = 363.922092576 cubic inches.
Something else interesting to note:
As far as the LS2 short block is concerned, its not much more than an old school 350, stroked just a litte bit:
old school 350:
bore = 4
stroke = 3.48
LS2
bore = 4
stroke = 3.62
[Modified by kewlbrz, 12:32 AM 1/7/2004]
Re: 5.7 to 6.0 - is it a 355? (kewlbrz)
Just to bring you guys up to date, GMPT does it's design work in metric dimensions and the nominal bore and stroke is 101.60 mm by 92.000 mm.
I previously ran the displacement calculations to five significant digits - 5967.0cc or 364.14 cubic inches.
Duke
[Modified by SWCDuke, 10:40 PM 1/6/2004]
Duke
Re: 5.7 to 6.0 - is it a 355? (BluByU)
talk about splitting hairs... :crazy: :p:
364 or 366 who cares?
What about those siamized cylinders and 4.0 bore. That sounds read close to the C5R block that also has siamized cylinders and comes with a 4.1 bore.
Now you don't think these two blocks bight possibly be the same or real close? I wonder how much the LS2 can be bored?
Just sitting hear at 6 degrees thinking about spring and what might be! :)
Re: 5.7 to 6.0 - is it a 355? (LT70ZR91)
:iagree:
:iagree:
[Modified by kewlbrz, 10:47 AM 1/8/2004]
