Siamesed bores and engine modifications
Old Jan 5, 2004 | 03:01 PM
DngrZne's Avatar
DngrZne
Default Siamesed bores and engine modifications
I'm assuming that now that we have siamesed bores tuners will be able to bore the cylinders out with less chances of complications. Also, just by stroking alone this gives a much better starting point.
I'm thinking also that this engine will respond very well to forced induction once the compression is lowered. Especially once Chevy releases the 3 valve heads.
I think a lot of the Vette's competition will be getting some big suprises :cheers:
Old Jan 5, 2004 | 03:07 PM
yellow01's Avatar
yellow01
Default Re: Siamesed bores and engine modifications (DngrZne)
I hope this isn't considered hijacking the thread, but can someone explain 'siamesed bores'? I'm not quite picturing what the heck that means.
:cheers:
Old Jan 5, 2004 | 03:14 PM
DngrZne's Avatar
DngrZne
Default Re: Siamesed bores and engine modifications (yellow01)
:cheers:
It means there are no cooling jackets in between the cylinders, just aluminum.
Old Jan 5, 2004 | 08:44 PM
I Bin Therbefor's Avatar
I Bin Therbefor
Actually iron. They're still using sleves. Old trick is to drill small hole at the top of the piston stroke between the cylinders in the joining material. Another about a half inch lower. Supposedly lets some water flow through between the cylinders to help cooling. :cool:
[Modified by I Bin Therbefor, 1:45 AM 1/6/2004]
Old Jan 5, 2004 | 09:24 PM
DngrZne's Avatar
DngrZne
Default Re: Siamesed bores and engine modifications (I Bin Therbefor)
Depends how close the liners are coming to each other. The engine has a 4.4" bore center with 4" bores leaving .4" between the cylinders. I believe the liners are relatively thin, so most of this extra space beteen the cylinders will still be aluminum, but it will also leave much more room for boring out the cylinders without worrys of hitting the cooling jacket. :cheers:
Old Jan 5, 2004 | 09:37 PM
SWCDuke's Avatar
SWCDuke
Hmmmm. The orignal Vega open deck block was later modified with slots between the cylinders to allow coolant flow in the upper quarter inch or so, but since the LS2 block is a closed deck design it may not be so, but it could be so designed.
Duke
Old Jan 6, 2004 | 02:06 AM
Runge_Kutta's Avatar
Runge_Kutta
Here's a recent GM patent on an aluminum siamese cylinder block. I think this
is directly relevant to Gen IV.
http://patft.uspto.gov/netacgi/nph-P...1&RS=6,349,681
Old Jan 6, 2004 | 02:34 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
:withstupid: :hat :thumbs:
Old Jan 6, 2004 | 03:42 AM
DngrZne's Avatar
DngrZne
Default Re: Siamesed bores and engine modifications (Runge_Kutta)
Interesting read :cheers:
Old Jan 6, 2004 | 11:33 AM
mikeivan's Avatar
mikeivan
Runge, thanks, that patent drawing is exactly the info I was looking for when I registered for this forum. How thick are those sleeves anyway? :thumbs:
Old Jan 6, 2004 | 05:46 PM
yellow01's Avatar
yellow01
Default Re: Siamesed bores and engine modifications (mikeivan)
Cool...that's neat as hell!
Old Jan 19, 2004 | 02:18 PM
LittleBoyBlu99
:cheers:
:cool: :cool: :thumbs:
Old Jan 19, 2004 | 07:40 PM
I Bin Therbefor
Much more efficient solution than drill holes or cast slots. Wonder how they got the heat pipe to work with all the vibrations and g loads on the working fluid. :cool:
To Siamesed bores and engine modifications
