The advance of engine technology
Ironic...
That's the thing. If you throw either of the Ford engines in the Corvette you'll get better 1/4 times and worse track times. The engines are heavy and large, putting the Corvettes center of gravity further forward and higher. Meanwhile the Chevy LSx engines are about the same weight as a Mazda rotary engine.
[Modified by Scissors, 9:25 PM 1/18/2004]
I recall seeing a "dressed weight" spec for the LS1 (inlet and exhaust manifolds, all accessories - alternator, a/c compressor, p/s pump and drive belt) with an auto trans flex plate and it was about 500 pounds.
I can't imagine that a rotary is much more than my Cosworth Vega engine, which is a little over 300 pounds, with only an alternator and 18 lb. flywheel.
Duke
Duke
Edit: And, yes, I believe it was the turbo engine. After all, if you're comparing weight and power, it's best to get one of them to be close to the other. ;)
[Modified by Scissors, 9:52 AM 1/19/2004]
400HP and 6L is great, but its relative. Just like the 5.0
Duke I've been arguing on this forum from the git go that pushrods do not mean old tech, nor to double overhead cam etc. equal high tech, but I think the ***/German advertising has taken it's toll and it seems a lost cause.
If all you care about is cheap RWHP and drag racing then a mustang is the way to go.
Does less HP=More advancement?
The rustang engine is probably poorly constructed but, this discussion is not about engine quality its about engine technology. If the rustang engine was made out of the same materials it would be better, Im sure.
[Modified by Jimwood, 12:41 AM 1/20/2004]
It ain't a lost cause until the enemy kills you. ;)
Duke
Duke
Todd
Yeah, there are a few guys who understand, but most don't get it. That's why I started the thread.
Duke
What does cheap RWHP have to do with the advancement of engine technology. Seems to me the more hp you can get with less cost shows advancement, as significant modifications do not need to be made.
First go read some engineering history, the double overhead cam, 4 valves and a supercharger were on the 1930s Dusenburgs, and the push rod V-8 was the holy grail of engineering because it would be more compact and less complicated. Other than computer control, the only real new advancements out there are the various variables, like variable camshafts, intakes, exhausts, and now from Saab displacement! And the only reason those German and *** engineers are forced to come up with these advances is because their engine displacements are taxed so heavily, if they had cheap gas and low taxes they would have the same engines that we do :yesnod:
[Modified by CPT Z06, 10:47 PM 1/20/2004]
[Modified by CPT Z06, 10:51 PM 1/20/2004]
Before the flames start, I know those other engines rev higher, but the difference is too great to ignore.
Having said that, there is alot more to an engine that hp/l. driveability, area under the curve, NVH, fuel efficiency, emissions and weight all factor into it. I'm happy with the compromises GM has made to make these engines a complete package.
Same materials? Is GM's steel and aluminum better than Ford's I don't think so, the engine is fine, nothing wrong with it really. I really don't understand the point you are trying to make :confused:
Also, I supposed I hijacked this thread a little bit. Sure GM has made excellent advances on old technology. To that extend you are correct. To the extent GM is advanced technology, I would have to disagree. Its just like improving the steam engine, its still a steam engine at the end of the day.
Just a comparison of HP output per Lt.
400HP out of 6L V8 (66.6 Hp per Lt.), is just not terribly impressive in 2005.
330hp out of 7.4(44.6 HP per Lt.) stock carb V8, Mercruiser in 1980.
410hp out of 4.6 (89.1 HP per Lt.) (Im not using Fords underated estimate)
By the way the reason I use HP is because that was your rationale for demonstrating the advancement.
And CPT :flag
Dont you think that advances with DOHC show better advances then with the pushrod. Hell even GM thought that was the best and made the LT5 :eek:
I havent seen your advanced pushrod technology beat any of the LT5 endurance records yet. :eek:
Whats your point again? SOHC, DOHC has made more advances then pushrod.
The argument that DOHC, SOHC came out before the pushrod doesnt mean anything when you are talking about engine advancement. As the pushrod is such recent new and god sent technology, then according to your reasoning it should be leaps and bounds farther then SOHC, DOHC, but its not.
Trust me I have looked at this throughly. Oh I forgot the 4.6 S/C has much more torque also all the way across the powerband.
The only legitimate argument I have read yet, is that technically a S/C is considered more displacement, at sanctioned racing.
The reason the C6 still uses pushrod is because old tech is cheaper to improve then replace outright. Improvement only means advancement in a vacuum. If you look at other engine designs currently out there the pushrod is outdated based on its HP and TQ numbers per litter.
:cheers:
[Modified by Jimwood, 6:40 AM 1/21/2004]
Also, you should count your SC displacement in a HP/Liter ratio. After I would pass a Porsche at a track I never had one of them walk up to me and say "Well at least I have variable valve timing" :lolg:
No doubt the SC 4.6 is a great motor, but its hp/liter output is due far more to the SC than to OHC technology.
There are drawbacks and benefits to both OHV and OHC, but to compare the two you need to talk about them in the same context - two engines with the same displacement, both either with FI or not, etc. Only then can you really compare the TECHNOLOGY of OHV vs. OHC.
On the other hand, if you just want to compare the 4.6 SC engine to LS1, etc., then obviously that's a different matter. But that argument does nothing to prove the advantage of OHC vs. OHV. It's simply a comparison of two different motors.
[Modified by COBrien, 9:24 AM 1/21/2004]
