active handling temporary abort switch
Old Apr 28, 2004 | 02:17 PM
Matt Gruber's Avatar
Matt Gruber
Default active handling temporary abort switch
i was thinking of a normally closed push button switch that could used for instant turn off. But, will it come back on within ~2 seconds?
any c5ers try this?(i may want it off in 1st gear, but on after that)
Old May 6, 2004 | 10:40 PM
johninar's Avatar
johninar
Default Re: active handling temporary abort switch (Matt Gruber)
Every time it's kicked in I was doing something wrong. I'll leave it on. Have you checked to see how long it takes to initialize? Then of course you have those days when it's "warming up" If you are going in a straight line, what harm is it doing? If you're not, don't you think you might need it?
Old May 7, 2004 | 06:30 AM
Matt Gruber
Default Re: active handling temporary abort switch (johninar)
hopefully it will work great.
i'll have to read the manual.
Old May 9, 2004 | 01:54 PM
Rocketblock's Avatar
Rocketblock
We have bumps in the Michigan roads. I have found with the traction control off it doesn't cut the throttle when it feels a skip from a bump when I am accelerating from my street onto the highway. I have almost gotten rear-ended by that feature when I most need the acceleration that I bought Corvette for in the first place. I drive with it off most of the time for this reason. I drove all of my previous cars and Corvettes without traction control... oh wait, they didn't have it!
Old May 9, 2004 | 02:36 PM
Matt Gruber
Default Re: active handling temporary abort switch (Rocketblock)
they seem to make improvements every year, so i hope it works good on my smooth roads. AH is a major reason for upgrading from my c3, it gets sideways sometimes on a WOT 1-2 shift@56mph and the last time it jumped clear into the next lane
Old May 9, 2004 | 02:55 PM
Corvette Junkie's Avatar
Corvette Junkie
Night Race Blue 427
From: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
Active handling and traction control are two different things. If you hold the traction control button down a few seconds you go in to competition mode. I competition mode traction control is off but active handling is still on.
Old May 9, 2004 | 04:07 PM
Matt Gruber
Default Re: active handling temporary abort switch (Corvette Junkie)
i hope to be able to switch it just once on the c6. let's see if they fixed that flaw.
Old May 11, 2004 | 09:11 PM
Painrace's Avatar
Painrace
If you are driving with the traction control on you are going too slow!
Old May 16, 2004 | 06:44 AM
TheDarkKnight's Avatar
TheDarkKnight
not when I'm autocrossing.
Old May 18, 2004 | 10:06 AM
johninar's Avatar
johninar
Default Re: active handling temporary abort switch (TheDarkKnight)
I'm referring to a road course. I'm sure a true professional does not want nor need it. I'm not and I admit I can use the help that active handling provides. As for turning it off as was mentioned at the top, indicates a straight line take off, not somewhere that it's going to affect you. He would be better served disabling the traction control so he could get the proper slip for max acceleration.
To active handling temporary abort switch
