Ethanol and Corvette
Old Aug 2, 2004 | 05:33 PM
Tabasco2's Avatar
Tabasco2
Default Ethanol and Corvette
Question: How do Corvettes C5 and C6's get along with ethanol?
I live in a state that 91 octane is max unless I go to a station that adds
a 10% ethanol mixture. By doing that they rate the octane at 93.
I have always heard that ethanol is not good for engines. Would hate
to use it and trash a new L2 engine in a C6.
Old Aug 2, 2004 | 09:16 PM
Michael A's Avatar
Michael A
Methanol is the one that's the really engine enemy. I believe GM says Ethanol up to 15% is OK (check your manual). I live in California, and they are already putting in Ethanol for 91 octane.
Michael
Old Aug 2, 2004 | 09:21 PM
Joezone914's Avatar
Joezone914
Michael
Are you kidding me, i did not know that there was ethanol in our gas here and that is what brought it to 91. Is this harmful? I wish we could get 93. I do occasionally get 100 at union 76. Runs quite nice!!!!!
Old Aug 3, 2004 | 12:48 AM
SWCDuke's Avatar
SWCDuke
Ethanol is the most common "oxygenate", and oxygenates are required in some parts of the country during the winter. In CA it is in our RFG II gasoline year round, but slightly less in summer than winter. It replaced MTBE that was recently outlawed.
Modern fuel systems are designed to operate on oxygenated fuels. Since ethanol oxygenated gasoline will absorb moisture more readily, there is increased potential for corrosion in the long term, particularly on cars that don't see a lot of mileage accumulation.
Duke
Old Aug 3, 2004 | 02:10 AM
Joezone914's Avatar
Joezone914
Thanx a lot for that info. Out of curiousity does the 100 octain fuel out here need more ethanol meaning is it more harmful to my engine than it is fun?
Old Aug 3, 2004 | 10:13 AM
SWCDuke's Avatar
SWCDuke
I would not describe ethanol as "harmful". Useless and expensive is more appropriate. I believe that the 100 PON Unocal gasoline has about the same amount of ethanol as common blends. Ethanol is an octane enhancer, but the Unocal 100 PON is achieved primarily by the hydrocarbon blend.
Duke
Old Aug 3, 2004 | 01:18 PM
Joezone914's Avatar
Joezone914
Duke
Duke,
Thank you very much for all the info.
Old Aug 3, 2004 | 02:10 PM
BRCC's Avatar
BRCC
Per C6 Owners Manual 5-5/5-6.
Gasoline Octane
Use premium unleaded gasoline with posted octane of 91 or higher for best performance. You may also use middle grade or regular unleaded gasoline rated at 87 octane or higher, but your vehicle's acceleration may be slightly reduced.
Additives
Gasoline containing oxygenates, such as ethers and ethanol, and reformulated gasoline. GM recommends you use these to contribute to clean air.
NOTE: Your vehicle is not designed for fuel that contain methanol. Damage caused by use of methanol would not be covered under your warranty.
Old Aug 4, 2004 | 12:44 AM
Michael A's Avatar
Michael A
Duke
And I might add that the Ethanol was forced on us in California by the Federal Government, who was lobbied by the farmers. California showed that even without MTBE, the oil companies were able to produce "clean" gasoline without adding expensive Ethanol.
Michael
Old Aug 4, 2004 | 01:29 PM
SWCDuke's Avatar
SWCDuke
The best science and engineering says that oxygenates have little value and are not at all justified because they increase fuel cost and fuel consumption while returning virtually nothing.
It's purely a political issue now. Write your Congressmen and Senators. The requirement is being driven by the EPA.
Duke
Old Aug 5, 2004 | 08:18 PM
juiced's Avatar
juiced
If you wan't real oxegenated fuel go buy a can of VP Racing U4 fuel. we ran it on a c5 with a wideband tuned at 12.? across the bored on 91. with the U4 it was running at almost 16:1 (15.8:1) to be exact. that stuff is insane and it's leaded. only try it if you don't have cats and don't really care for your o2's
Old Aug 5, 2004 | 09:39 PM
Vette_DD's Avatar
Vette_DD
I thought GM said that 93 octane gas was recommended for the LS2, but not required.
Old Aug 16, 2004 | 10:27 AM
PeterHPE's Avatar
PeterHPE
3rd Gear
Default Octane
I live in Sweden and the only gas we have here is unleaded 95 and 98. That translates into more performance, right? That is fun and all, but the gas price here is steep to say the least, we´re talking 1,2$ per litre, not sure about the gallon price.
/Peter
Old Aug 16, 2004 | 11:04 AM
SWCDuke's Avatar
SWCDuke
There are at least three different ways to measure octane number - Research Octane Number (RON), Motor Octane Number (MON) and Pump Octane Number (PON), which is the arithmetic average of RON and MON.
In the US PON is the standard? An estimate of RON can be made by adding 4 to 5, and MON can be estimated by subtracting 4 to 5.
A different test is used for aircraft gasoline octane number, but the result is close to MON.
So which of the above methods are used for octane number rating in Sweden, or maybe there is a different standard in Europe?
Maximum performance is achieved if octane is sufficient to prevent any detonation that causes the PCM to retard the spark. In normal weather and driving conditions this is probably achieved with 93 PON.
Duke
Old Aug 19, 2004 | 07:56 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Duke
Gotta get the Iowa, Nebraska, and IL vote, who cares if it really works?
Old Aug 19, 2004 | 10:31 PM
lt1george's Avatar
lt1george
Default gas
Only heard bad things about that Ethanol.>George
To Ethanol and Corvette
