I am trying to decide which programmer to purchase. I would like to know how many extra horses I can expect to get if I max out the programmer. Will one give me more than another or are they all about the same? I would also like to know how the various stages of programming will affect my fuel mileage. Any help would be greatly appreciated.
I don't think they will get you anything. They did not on my 01 Tahoe, even though it was designed for regular fuel, and supposedly the programmer optimizeed it for premium. In my three years on this forum, I have yet to see anyone post any results that concluded these programmers added any horsepower at all.
I don't think my answer would be any different whether you are referring to a C5 or C6.
I don't think they will get you anything.... In my three years on this forum, I have yet to see anyone post any results that concluded these programmers added any horsepower at all.
Maybe not on this forum, but if it does nothing, then why are new computers and reprogramming such a big part of ricing out a car?
The simple answer to your question is because many of the cars you refer to are turbocharged. If you are dealing with a turbocharged or supercharged car, you can progam a computer to allow more boost, which is easy horsepower - but almost always at the expense of reliability.
For normally aspirated, stock or mildly modified, cars I don't believe that chips do much.
On the other hand, if you do enough modifying to you car, a chip can be a valuable tool in extracting the most hp from your heavily modified car.
On the vette you might get a couple ponies. Not worth it. Hard to tell until we see the mapping but it's pretty well dialed already. You can firm up shifts and raise limiters to get a little umph. Tuners have their spots on diesel trucks with electroinically controlled waste gates.
One thing I didn't mention was some of the auto cars can get better shift points and firmness with a chip.
I always have sticks so I didn't think of that right away.
A total waste of $$$....Do a search on it there where some before and after #s...Buyer beware
With a Diablo Power Programmer you can alter the fuel and spark curves yourself or a technician can. You need to have a couple of hours access to a chassis dyno. The cars are too rich at full or near full throttle. The dyno tune gets the power from leaning this out plus adding some spark advance. It can do as much as 20-30HP.
You do need to be careful not to go too lean as then detonation can be a problem. Over all with the dyno time, this is going to cost you nearly $800.00 or so.
As for the programmers with "drop and tune" setup, there is not a lot to be gained.
1) Never RICE out a Vette.
2) Tuning is different than reprogramming. It is done to make adjustments after modifactions that will affect the performance have been made.
3) "Programmers" change shift points/shift speeds etc. Other than on a diesel where they will allow more exhaust into the turbo to allow for higher boost #'s will you ever see much of a gain.
4) Please don't use RICE & VETTE in the same sentence again.
