Those numbers are closer to what I hoped the C6 would do. Somebody needs to get 5K miles on one quick and post some numbers. Maybe this thing will do 360/360 broken in.
I had my silver 2004 Z06 on the dyno at Carlisle this past weekend right before the C6 of Lance Miller went on. My car is bone stock with just over 2,000 miles. My numbers were 360.5 rwhp and 347.4 rwtq. In defense of the C6, as has been noted, this car only had 15 miles on it, so it should certainly do better with more miles. Of course when Callaway gets done with this particular car, it'll probably put down huge numbers. Actually, if my calculations are correct, 348 rwhp equates to about 400 hp at the crank, so the C6 is right on the money for horsepower. I think the LS2 will be a great engine, with plenty of potential for increasing power.
StealDads67,
That's a great handle, and if my Dad would have had a 67, I would have stolen it too. Thanks for the compliments about my dyno run. I was hoping for around 350-360 so I'm real happy with 360.5 rwhp.
OK, I'm in over my head here but I'll ask. Why is the drive train % loss greater with the performance axle than without? That seems backwards.
~john
I'm still not totally convinced that percentage loss is accurate concidering all the variables that are non linear. I guess to simplify, why do I loose more hp with an LS2 vs an LS1, 15% for C5 is a 52.5hp loss and for the C6 it is 60hp. Can anyone get a chart of the Engine Dynoed by itself.
~john
With the performance axel, the drivetrain is accelerated faster, and thus the mass of the drivetrain itself becomes a bigger factor. Force = mass x acceleration.
The mass is the same with perf axle and without, but since the gearing is lower, the acceleration is faster, and thus the "force" required to make it accelerate is also greater, and that's less force that actually makes it to the wheels.
Yeah it is nonlinear, the amount you lose to the drivetrain and rotating assemblies actually increases as you increase power at the flywheel. This is why dynos are run in higher gears-- if you ran in first gear, you lose a much higher percentage to just getting the drivetrain spinning.
That mass relative to the entire vehicle is negligible and when calculating the gear advantage reduces that effect by that same factor making it even less a factor. Then why with the same gears but a different engine is there a different loss. Would like to see the raw engine over the same rev range to do a comparison.
I hear ya' ... but how does that pan out in the real world (away from the calculator). Does it really equate to the calculated 3% variance derived from the mathematics?
~john
Because the further from a 1:1 ratio you get, the less efficient the gearing is. On the C5 every .3 increase results in approximately 10 more HP lost at the wheels. Of course, acceleration is improved because the torque multiplication is better, resulting in more torque at the wheels.
So the swapping from the 3.15 to the 3.42 on the C5 results in an approximate 10 HP loss at the wheels because the 3.42 is less efficient. But because the 3.42 is a higher torque multiplier, acceleration is improved.
This is why the A4 is dynoed in 3rd gear (1:1 ratio) and the M6 is dynoed in 4th gear (1:1 ratio.) This minimizes drivetrain losses as the 1:1 ratio is the most efficient.
The proof is in the pudding. Time and time again the early A4 C5s would dyno 286 with the performance axle and 295 with the base axle. This has also been observed by those who change their rear end gear.
It would appear that the M6 C6 loses 13%, as shown by several dynos.
I have seen this too; I guess it didn't dawn on me as to the actual percentage it represented.
