Dump The Mobil 1
How about the idea of dumping the Mobil 1 immediately, switching to regular oil (say 5w30) for the first 1000 miles, and than using synthetics for the life of the VETTE.
Again , I believe in synthetics. I'm not a expert on oils--but sometimes I believe the only reason Vettes come with Mobil 1 is because of some joint marketing venture between GM and Mobil.
Any opinions??
That you can't break in an engine with synthetics is one of those "urban legends" that persists from the early days of synthetic's introduction - in my opinion.
Break-in is mostly about heat cycles and, to a much lesser extent, wear. But that wear is easily achieved no matter what oils you use.
Not to mention that a lot of break-in is for the transmission, differential, and brakes. Changing your engine oil won't change any of that.
"Breakin wear" is not measurable with conventional tools. An electron microscope might show it.
Duke
And then, only after a preceeding change interval of 50/50 conventional and synthetic before the final full strength dose. Imagine that. Like an engine is a living thing that needs a period of adjustment to acclimate itself before being subjected to the full monty.
But those guys aren't nearly as smart as Y'all.
Regards,
Vince
coming back from autocross yesterday in 106 az heat at 90 mph with 4.10 rear , rpm at 3300 or so and oil temp at 243...was very glad to have mobile 1 ....i would not leave home without it
Of course I could be wrong, but that was my own personal experience.
Any opinions??
The less wear on the engine the better. Period.
there is a huge difference the first time you start the engine and 500 miles, 2000 and 5000 miles later in performance but also in consumption and you ear the engine idling diferently.
On the Vette never see any difference from mile 1 to now. And I speed up to 170 miles after 200 miles.
That used to be the case 15 years ago, but no longer:
Myth: You should break in your engine with conventional oil, then switch to Mobil 1.
RealityYou can start using Mobil 1 with SuperSyn™ in new vehicles at any time, even in brand-new vehicles. In fact, Mobil 1 with SuperSyn™ is original equipment (it is installed at the factory) in:
Chevrolet Corvette
All Porsche vehicles
Mercedes-Benz AMG vehicles
Dodge Viper
Ford Mustang Cobra R
All Aston Martin cars
One of the myths that persists about Mobil 1 is that new engines require a break-in period with conventional oil. Current engine manufacturing technology does not require this break-in period. As indicated by the decisions of the engineers who design these high-performance cars, Mobil 1 with SuperSyn™ can be used in an engine from the day you drive the car off the showroom floor.
and this from Pat Goss:
Another big misconception, says Goss, is that new engines require a break-in period with conventional oil, and then drivers can switch to a synthetic. In fact, today's engine technology does not require this break-in period.
and this from the Quaker State web site:
Myth #6
Engines have to be “broken in” before using synthetic oil.
I need to break in my engine with non-detergent oil.
If I use regular oil or synthetic oil in a new engine, my engine will take longer to break in.
Fact
It was common years ago for engine manufacturers to recommend non-detergent oils for engine break-in. This was when the pistons used cast-iron “square-faced” rings and the rings needed to wear some to “seat” into the engine. With today’s technology of oils and engine manufacturing, engine manufacturers no longer recommend the use of non-detergent oils for the break-in period. In fact, engines today are factory-filled with high quality API SL performance motor oil, which contains high levels of detergents and dispersant additives.
But, I agree with the others. I wouldn't worry about it. Every T1 racer I know just drops a new motor in the car, adds a good synthetic, warms the oil up to 120 or so, and goes...
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
I don't have any idea what agreement GM and Mobil 1 have, but I would venture to guess that is beneficial to both of them. If Mobil 1 gave GM "free" oil for new cars, that saves GM millions of dollars per year. In turn, GM is giving Mobil 1 customers, because the vast majority of owners will continue to buy Mobil 1 for the life of the car.
I would suspect Goodyear and GM have a similar type of relationship. Maybe not free tires, but do you really think GM is paying what we are paying for tires?
And while I can't comment on the specifics of my relationship with AMSOIL, yes, I am sponsored by AMSOIL. However, it was after obtaining sponsorship that I became so impressed with their full product line, vice just the racing lubricants that I was using in my Z06, that I became an Independent AMSOIL Dealer. I do buy my oil, filters, wiper blades, etc for my F350 and Chevy Trailblazer from AMSOIL at wholesale, same as any other preferred customer or dealer.
C6vette,
Sorry for the hijack.
Same thing with Goodyear.
Regards,
Vince
